The node setup is under a LXC docker in Proxmox. Disk is mounted from another NAS through iSCSI. The node has been working properly and recently the size has reached the disk size originally set.
I updated the docker compose file with
environment:
**- STORAGE=9TB**
I expect it should be changed to 9TB. However, the disk size shown in the Node Dashboard is only 8.12TB.
