Hi all,
Just installed GUI of 0.30.5, port forward is fine/open, windows firewall rule added as is shown in manual, GUI setup went fine like in manual. Where is the issue?
Thanks, K.
Hi all,
Thanks, K.
please write your config, here.
Do you use DDNS or Static IP?
Stop/Shutdown request received.
2020-01-26T09:05:31.050-0800 INFO Configuration loaded from: C:\Program Files\Storj\Storage Node\config.yaml
2020-01-26T09:05:31.051-0800 INFO Invalid configuration file key: storage.allocated-disk-space
2020-01-26T09:05:31.051-0800 INFO Invalid configuration file key: server.debug-log-traffic
2020-01-26T09:05:31.051-0800 INFO Invalid configuration file key: storage.path
2020-01-26T09:05:31.051-0800 INFO Invalid configuration file key: server.address
2020-01-26T09:05:31.051-0800 INFO Invalid configuration file key: server.private-address
2020-01-26T09:05:31.051-0800 INFO Invalid configuration file key: operator.email
2020-01-26T09:05:31.051-0800 INFO Invalid configuration file key: storage.allocated-bandwidth
2020-01-26T09:05:31.051-0800 INFO Invalid configuration file key: operator.wallet
2020-01-26T09:05:31.051-0800 INFO Invalid configuration file key: contact.external-address
2020-01-26T09:05:31.052-0800 INFO Invalid configuration file value for key: log.encoding
2020-01-26T09:05:31.555-0800 INFO Downloading versions from https://version.storj.io
2020-01-26T09:05:32.910-0800 INFO storagenode version is up to date
2020-01-26T09:05:32.910-0800 INFO Downloading versions from https://version.storj.io
2020-01-26T09:05:33.036-0800 INFO storagenode-updater version is up to date
There shold be a port also
with “:” between ip and port?
Yes 78.56.33.139:28967
restart node service after config change.
restarted, same reaction.
https://www.yougetsignal.com/tools/open-ports/
this show that your port is open, refresh your dashboard
Yes, port is open. i can see requests on packets in my router
what your logs showing?
What else did you edit in the config file?
nothing. only added port to ip
These are showing errors as if something is missing from the config
seems like everything is missing
it is info not ERROR
try tern off your windows firewall at all, some time it block to out also.
ok, in conf file found that an all those invalid line are missing “#” sign. ill try to add them
this will comment them.
firewall is down. same issue. any ideas?
Was this the newest installer for windows GUI?
