yes. the last one what is added to the link in the manual
Some reason im not able to reproduce those config file invalid line by changing everything in the config, maybe you can try to uninstall the GUI and make sure that config file is deleted then install it again.
i can try once again
after clean uninstall with cleaner and new install status now is online and even 660.74KB of data
. thanks.
Glad it worked not sure what the issue may have been though.
i think issue came from the setup process it-self. i started setup, and on half way of that i started doing powershell things, then continued β¦ maybe some data failed in some case.
anyway, million thanks for support
Hey.
I have exactly the same problem
| 2020-01-28T15:29:49.322+0300 | INFO | Stop/Shutdown request received. |
| 2020-01-28T15:29:57.921+0300 | INFO | Configuration loaded from: C:\Program Files\Storj\Storage Node\config.yaml |
| 2020-01-28T15:29:57.938+0300 | INFO | Invalid configuration file key: storage.path |
| 2020-01-28T15:29:57.938+0300 | INFO | Invalid configuration file key: preflight.database-check |
| 2020-01-28T15:29:57.938+0300 | INFO | Invalid configuration file key: version.check-interval |
| 2020-01-28T15:29:57.938+0300 | INFO | Invalid configuration file key: storage.allocated-disk-space |
| 2020-01-28T15:29:57.938+0300 | INFO | Invalid configuration file key: storage.allocated-bandwidth |
| 2020-01-28T15:29:57.938+0300 | INFO | Invalid configuration file key: operator.email |
| 2020-01-28T15:29:57.938+0300 | INFO | Invalid configuration file key: contact.external-address |
| 2020-01-28T15:29:57.938+0300 | INFO | Invalid configuration file key: color |
| 2020-01-28T15:29:57.938+0300 | INFO | Invalid configuration file key: server.debug-log-traffic |
| 2020-01-28T15:29:57.938+0300 | INFO | Invalid configuration file key: operator.wallet |
| 2020-01-28T15:29:57.938+0300 | INFO | Invalid configuration file key: server.address |
| 2020-01-28T15:29:57.938+0300 | INFO | Invalid configuration file key: server.private-address |
| 2020-01-28T15:29:57.938+0300 | INFO | Invalid configuration file value for key: log.encoding |
| 2020-01-28T15:29:58.023+0300 | INFO | Downloading versions from https://version.storj.io |
| 2020-01-28T15:29:58.634+0300 | INFO | storagenode version is up to date |
| 2020-01-28T15:29:58.634+0300 | INFO | Downloading versions from https://version.storj.io |
| 2020-01-28T15:29:58.778+0300 | INFO | storagenode-updater version is up to date |
Try fresh, clean install when identity is created. Remove storj instalacion with some cleaner to clean out registry aswell then install again
Which cleaner ?? This is the help of a 5 year old schoolboy! And who will restore the computer to me later?
System update does not work correctly.
With this program itself works, there is traffic, but it could not be updated.
The point of automatic updates if it does not work correctly?
This is a bug, and it needs to be fixed.
Reinstalling the program did not help.
What else can you do? to run with a tambourine?
As a result, I updated it manually, there is traffic, there is an error.
What to do? Score until next update?
i use IObit uninstaller to remove unused files. Before doing something that You thin it is not safe for your software/app - make backup!!!
Hey dude, if tambourine helps to solve the problem - use it and give feed back about the model you used.
But donβt forget - V3 is in beta, so no 100% that it will work fine on all PCβs. Donβt panic and open a personal issue chat for support to see it!
God luck
INFO Configuration loaded from: C:\Program Files\Storj\Storage Node\config.yaml
INFO Operator email:
INFO operator wallet: 0xB5f01aac6ad6D70cF751b82f9A5e0201bE1901C5
INFO version running on version v0.30.5
INFO db.migration Database Version {βversionβ: 28}
INFO preflight:localtime start checking local system clock with trusted satellitesβ system clock.
INFO preflight:localtime local system clock is in sync with trusted satellitesβ system clock.
INFO Node 1NSnmm9t5o2dvBE2C8yhonAjcPUZyNRaoAtJ5aq8q5a2zbs959 started
INFO Public server started on [::]:28967
INFO Private server started on 127.0.0.1:7778
INFO bandwidth Performing bandwidth usage rollups
INFO trust Scheduling next refresh {βafterβ: β2h44m9.674814067sβ}
INFO piecestore:monitor Remaining Bandwidth {βbytesβ: 199964122870528}
Further
INFO Invalid configuration file key: contact.external-address
INFO Invalid configuration file key: server.private-address
INFO Invalid configuration file key: storage.path
INFO Invalid configuration file key: storage.allocated-disk-space
INFO Invalid configuration file key: server.address
INFO Invalid configuration file key: operator.email
INFO Invalid configuration file key: storage.allocated-bandwidth
INFO Invalid configuration file key: server.debug-log-traffic
INFO Invalid configuration file value for key: log.level
INFO Downloading versions from https://version.storj.io
INFO storagenode version is up to date
INFO storagenode-updater version is up to date
did not help.
Your options?
Looks like you edit your config file not with a Notepad++, but regular Notepad.
Please, never use a regular Notepad or WordPad to edit a config files. They are places special symbols to there and even can broke it.
Please, upload here your config file before processing further, Iβll point to it our dev team.
Please, install the Notepad++, open your config.yaml. If you see a special symbols in the beginning of the config - please, remove them and save the config file in the UTF8 encoding without BOM, the Unix ending (LF)
After that restart the service either from the Services applet or from the elevated Powershell:
Restart-Service storagenode
Just a note, a normal user will never need to edit the config.yaml. Everything in there should be left as is until instructed by support. Every change should be done in the docker run command. Donβt know how the GUI version works though. I assume there is an option somewhere to add ports, wallet, email etc.
This should help
So I was right ![]()
Partially. On initial install with windows GUI you can enter all values during setup. But you will need to edit the config.yaml if you want to make changes afterwards.
Always use Notepad++ .
did not help.
Where to download the file?
Nice one!
Please, edit your config file with the Notepad++ and specify your external address with port in the contact.external-address: option and your wallet in the operator.wallet: option, save the config and restart the storagenode service.
Looks like a bug in the migration of the config file to a new format.
ΠΡΠ΅Π½Ρ Π»ΡΠ±ΠΎΠΏΡΡΠ½ΠΎ!
Π£ Π²Π°Ρ Π½Π΅ Π·Π°Π΄Π°Π½Ρ Π½ΠΈ Π²Π½Π΅ΡΠ½ΠΈΠΉ Π°Π΄ΡΠ΅Ρ, Π½ΠΈ ΠΊΠΎΡΠ΅Π»ΡΠΊ. Π£ΠΊΠ°ΠΆΠΈΡΠ΅ ΠΈΡ
, ΠΏΠΎΠΆΠ°Π»ΡΠΉΡΡΠ°, Π² config.yaml, ΡΠΎΡ
ΡΠ°Π½ΠΈΡΠ΅ ΠΈ ΠΏΠ΅ΡΠ΅Π·Π°ΠΏΡΡΡΠΈΡΠ΅ ΡΠ΅ΡΠ²ΠΈΡ storagenode.
ΠΠΎΡ
ΠΎΠΆΠ΅ Π½Π° ΠΎΡΠΈΠ±ΠΊΡ ΠΏΡΠΈ ΠΌΠΈΠ³ΡΠ°ΡΠΈΠΈ ΡΡΠ°ΡΠΎΠ³ΠΎ ΠΊΠΎΠ½ΡΠΈΠ³Π° Π² Π½ΠΎΠ²ΡΠΉ.
I just removed this data.
What not to show everyone.
I see that the topic also contains errors
