You sent me the edited config? This will not help to squash the possible bug
Please, send the raw file as an attachment.
Or you can use the https://support.storj.io to submit a ticket. Then I’ll work on it there.
#3564
Technical support request sent
9 posts were split to a new topic: Used_serial: schema check failed: database disk image is malformed
