Rebooted, this time node ran longer
Log file start:
2022-06-28T14:52:59.389+0300 INFO Configuration loaded {"Location": "C:\\Program Files\\Storj\\Storage Node\\config.yaml"}
2022-06-28T14:52:59.399+0300 INFO Operator email {"Address": "audrius.alt@gmail.com"}
2022-06-28T14:52:59.399+0300 INFO Operator wallet {"Address": "0x9aB0bfD9659E19Ac947ded50D22cEC038F336Ebd"}
2022-06-28T14:53:02.048+0300 INFO Telemetry enabled {"instance ID": "1nd2G2CiFTfLPTTrxbErwZJL7NuyXJsDZsLXqT9oEVjwEdQZSa"}
2022-06-28T14:53:02.087+0300 INFO db.migration Database Version {"version": 53}
2022-06-28T14:53:03.482+0300 INFO preflight:localtime start checking local system clock with trusted satellites' system clock.
2022-06-28T14:53:04.476+0300 INFO preflight:localtime local system clock is in sync with trusted satellites' system clock.
2022-06-28T14:53:04.534+0300 INFO Node 1nd2G2CiFTfLPTTrxbErwZJL7NuyXJsDZsLXqT9oEVjwEdQZSa started
2022-06-28T14:53:04.534+0300 INFO Public server started on [::]:28967
2022-06-28T14:53:04.534+0300 INFO Private server started on 127.0.0.1:7778
2022-06-28T14:53:05.405+0300 INFO piecestore upload started {"Piece ID": "ZEKECPZJ5UEXXLAUBMWIHVYZPBD6IH3VLKWVB3YG2F6XSATAC2OQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 2856611035648}
2022-06-28T14:53:05.360+0300 INFO trust Scheduling next refresh {"after": "6h15m31.896814561s"}
2022-06-28T14:53:05.458+0300 INFO bandwidth Performing bandwidth usage rollups
2022-06-28T14:53:06.198+0300 ERROR collector unable to delete piece {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "RFO662IIHTP6Q35NHB7PG6YMNKUS7HRSHUPY2ZIFRG44GHWQFLNA", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-06-28T14:53:06.227+0300 ERROR collector unable to delete piece {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "C6F46E4LNBHSXEIHCBKRNRDZJNTZBRJNP5RLQLCOY5UQHZF5FEVA", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-06-28T14:53:06.227+0300 ERROR collector unable to delete piece {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "C6W7RJZ3CQL547ZOHZX5AK36LDVFFJ4SPFXZKZL267VBGUWDZATQ", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-06-28T14:53:06.254+0300 INFO piecestore download started {"Piece ID": "SRNZBRHB6J7LQJ663EZRR6WUTLAODSQGFVPGMPADPPKOPA5L7IQQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET"}
2022-06-28T14:53:07.066+0300 INFO piecestore download started {"Piece ID": "YUWL2YBBZLQRBW57XC2M7TSICKUTWW6HAYD65ROIYRBD7VBSV6HA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET"}
2022-06-28T14:53:07.276+0300 INFO piecestore downloaded {"Piece ID": "SRNZBRHB6J7LQJ663EZRR6WUTLAODSQGFVPGMPADPPKOPA5L7IQQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET"}
There is some errors in the middle like:
2022-06-28T14:53:12.499+0300 ERROR blobscache satPiecesTotal < 0 {"satPiecesTotal": -1812736}
2022-06-28T14:53:12.499+0300 ERROR blobscache satPiecesContentSize < 0 {"satPiecesContentSize": -1812224}
and
2022-06-28T15:09:36.129+0300 ERROR piecestore download failed {"Piece ID": "JOCMYFQDIWWABXGFQYPWISTAGA45PPGKYH5VCLJJNQ3JSFMSXDIQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:73\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:546\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:228\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:122\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:112\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52"}
and log file ends with fatal:
2022-06-28T15:18:24.047+0300 ERROR piecestore:cache error getting current used space: {"error": "readdir F:\\Storj_storage\\blobs\\ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa\\at: The system cannot find the path specified.; readdir F:\\Storj_storage\\blobs\\v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa\\c6: The system cannot find the path specified.", "errorVerbose": "group:\n--- readdir F:\\Storj_storage\\blobs\\ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa\\at: The system cannot find the path specified.\n--- readdir F:\\Storj_storage\\blobs\\v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa\\c6: The system cannot find the path specified."}
2022-06-28T15:18:24.047+0300 ERROR services unexpected shutdown of a runner {"name": "piecestore:cache", "error": "readdir F:\\Storj_storage\\blobs\\ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa\\at: The system cannot find the path specified.; readdir F:\\Storj_storage\\blobs\\v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa\\c6: The system cannot find the path specified.", "errorVerbose": "group:\n--- readdir F:\\Storj_storage\\blobs\\ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa\\at: The system cannot find the path specified.\n--- readdir F:\\Storj_storage\\blobs\\v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa\\c6: The system cannot find the path specified."}
2022-06-28T15:18:24.049+0300 INFO piecestore upload canceled {"Piece ID": "HMM437ZI6ZYM77AVIUMHMMEFOMLQP7AMQUN3B6JUIBBOZBLBEAXA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Size": 1581056}
2022-06-28T15:18:24.049+0300 INFO piecestore upload canceled {"Piece ID": "SHRSWWAZVQM63UBT3FK4JAQU6PRQYIHOLLGNTLI2IH2INKM6Y4NA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Size": 794624}
2022-06-28T15:18:25.510+0300 FATAL Unrecoverable error {"error": "readdir F:\\Storj_storage\\blobs\\ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa\\at: The system cannot find the path specified.; readdir F:\\Storj_storage\\blobs\\v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa\\c6: The system cannot find the path specified.", "errorVerbose": "group:\n--- readdir F:\\Storj_storage\\blobs\\ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa\\at: The system cannot find the path specified.\n--- readdir F:\\Storj_storage\\blobs\\v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa\\c6: The system cannot find the path specified."}
