Nodes are offline, no errors
Greetings, as you can see in the photo I added, all my nodes are offline and none of them have any errors. They all went offline at the same time and they are operating in different locations. All of them went offline at exactly 15:30.
(I cant upload more photo than one because i am a newbie in this forum :frowning: )
I clicked on your duckdns.org link… and the node looks up?
Oh man, i am in University Library, they blocked external ip’s :joy:
Thanks. so solved
Did you started a node on Univeristy’s PC? Or I get it wrong?
You should not expose your Dashboard to public internet in the first place! Not recommended , not safe.
So many things wrong here.
  1. Don’t expose internal ports, including for dashboard. Configure your firewall properly. (security)
  2. Don’t use duckdns. (reliability)
  3. Don’t misuse university resources. (self explanatory)
i was checking my node status. They are not comnected to University :rofl:
Can you delete this Photo please :frowning:
Hello @sencer,
It’s better to use either How to remote access the web dashboard - Storj Docs or [Tech Preview] Multinode Dashboard Binaries instead of publishing the node’s dashboard without any protection.
A verry secure, reliable and useful way to remotely monitor and access your nodes is to use a VPN.
I use Wireguard server on my router and Wireguard client on my phone and PC.
I cand safely access all my LANs from werever, check the dashboard, do some maintenance, etc.
No need to expose your ports to internet.
You need a router that supports Wireguard VPN.
I use exactly the same approach, works great from PC, phone and tablet.
