Good evening,
I’m Giak and i’m from Italy.If there is a dedicated topic for greetings i’d be glad to write there.
My problem is that my node randomly goes offline, so i need to restart it to make it working again.
It happens about every 100 hours of node uptime (i run it on raspberry pi4).
I’m using a VPN 'cause my isp uses nat so i couldn’t be reachable without it.
I’m also using a ddns 'cause i don’t have a static ip.
Port forwarding works correctly, is there anything else i could check?
Oh i thought i could change the path i wish.
However now i enabled the log and everything works correctly.
As i get more information i’ll let you know, thanks !
Ignore error for 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW as this satellite has shut down.
Go to your folder for orders/unsent remove the oldest 5 files that would have nearly same timestamp. These 5 files represent orders for 5 satelllites. You can save them in another folder too if you want. Then restart your node. Observe the log to make sure you see sending for orders which will prove your issue was fixed.
This is probably related to the shutdown stefan-benten satellite, which you can confirm by checking for the satellite ID: 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW . You can ignore errors related to this satellite. So your problem must be something else. I would double check that your DDNS updater is working properly. If you use no-ip, the account must be verified manually once per month I believe.
@baker yes it’s that satellite, infact i’m ignoring those errors. @nerdatwork i took a look, my problem is that my ip is under nat so without a ddns i can’t use my node.
Next time i try to run a new node directly with vpn server’s ip (even if it is dynamic) but until my connection is up, it doesn’t change so i give a try.
I Found the problem, DUC wasn’t working well, so as my vpn server changed ip address, the connection stopped working.
I made some tests and DDNS always point to the right IP now.
You can close this thread.
