Not sure if this is normal / has the version been reverted due to bug ?
I did a manual pull from docker pull storjlabs/storagenode:0c21bd6
But still appears 1.95.1
Thanks in advance
Thanks in advance
I donāt have an answer for you: but Iāve seen something similar. Lots of nodes that were 1.96.6 went backwards to 1.95.1 once it became the new minimum version.
They still seem to work fine, so I havenāt been concerned.
cheers for responding.
Yeah, no issues - just worried it might fall behind, but hopefully not.
Iāve seen 1.99 in the github, but assume thats testing currently.
This is okay and expected.
We had a bug causing some windows nodes to crash on version 1.97.2, so we stopped the rollout and issued a downgrade.
Has the upgrade been blocked only on Windows? Version 1.97.2 of the storagenode for Windows can still be downloaded on github
i have upgrade 10 nodes to 1.97.2 on windows and i havenāt nothing problems. I have upgrade manualy.
It has these issues:
