Please suggest me how to do a graceful exit
NO. I did not enter this command.
If you read the guide carefully, you will notice what to enter as the first command.
storagenode exit-satellite
C:\Users\dhiwa>storagenode exit-satellite
‘storagenode’ is not recognized as an internal or external command,
operable program or batch file.
C:\Users\dhiwa>
“C:\Program Files\Storj\Storage Node\storagenode.exe” exit-satellite
C:\Users\dhiwa>“C:\Program Files\Storj\Storage Node\storagenode.exe” exit-satellite
2020-02-27T09:47:05.300+0545 FATAL file or directory not found error: open C:\Users\dhiwa\AppData\Roaming\Storj\Identity\Storagenode\identity.cert: The system cannot find the path specified.
C:\Users\dhiwa>
Do you see 6 files in this location ?
No. But I see them in other location. i.e “C:\Users\dhiwa\Desktop\storj\identity\identity\Storj\Identity\storagenode”
Copy the 6 files from desktop to C:\Users\dhiwa\AppData\Roaming\Storj\Identity\Storagenode
I can only see folders upto Roaming. Should I create the rest of the folders and copy the content there?
Yes. This is the default location for your node’s identity.
what should I do after that?
Execute the command
Microsoft Windows [Version 10.0.18362.657]
(c) 2019 Microsoft Corporation. All rights reserved.
2020-02-27T10:32:23.375+0545 INFO Node ID: 12CQfR2oQBwFK3k1QjXFSjaP5ZjpNws2zxWRwuDJoF8uvg7MWU5
Please be aware that by starting a graceful exit from a satellite, you will no longer be allowed to participate in repairs or uploads from that satellite. This action can not be undone. Are you sure you want to continue? y/n
: y
Can’t find any non-exiting satellites.
Error: rpccompat: dial tcp 127.0.0.1:7778: connectex: No connection could be made because the target machine actively refused it.
C:\Users\dhiwa>
Now I am back on track
2020-02-27T10:45:34.171+0545 INFO Node ID: 12CQfR2oQBwFK3k1QjXFSjaP5ZjpNws2zxWRwuDJoF8uvg7MWU5
: y
Domain Name Node ID Space Used
satellite.stefan-benten.de:7777 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW 220.2 GB
saltlake.tardigrade.io:7777 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE 423.7 MB
asia-east-1.tardigrade.io:7777 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 7.8 GB
us-central-1.tardigrade.io:7777 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S 2.8 GB
europe-west-1.tardigrade.io:7777 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs 135.0 GB
Please enter a space delimited list of satellite domain names you would like to gracefully exit. Press enter to continue:
What should I do?
can all be done at once?
Now this is what I get.
Domain Name Node ID Percent Complete Successful Completion Receipt
satellite.stefan-benten.de:7777 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW 0.00% N N/A
C:\Users\dhiwa>
: y
2020-02-27T10:54:14.465+0545 INFO Node ID: 12CQfR2oQBwFK3k1QjXFSjaP5ZjpNws2zxWRwuDJoF8uvg7MWU5
: y
europe-west-1.tardigrade.io:7777 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs 135.1 GB
Invalid input. Please use valid satellite domian names.
Error: Invalid satellite domain names
2020-02-27T10:54:28.096+0545 INFO Node ID: 12CQfR2oQBwFK3k1QjXFSjaP5ZjpNws2zxWRwuDJoF8uvg7MWU5
: y
europe-west-1.tardigrade.io:7777 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs 0.00% N N/A
2020-02-27T10:55:10.489+0545 INFO Node ID: 12CQfR2oQBwFK3k1QjXFSjaP5ZjpNws2zxWRwuDJoF8uvg7MWU5
: y
saltlake.tardigrade.io:7777 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE 0.00% N N/A
2020-02-27T10:55:47.182+0545 INFO Node ID: 12CQfR2oQBwFK3k1QjXFSjaP5ZjpNws2zxWRwuDJoF8uvg7MWU5
: y
asia-east-1.tardigrade.io:7777 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 0.00% N N/A
2020-02-27T10:56:14.150+0545 INFO Node ID: 12CQfR2oQBwFK3k1QjXFSjaP5ZjpNws2zxWRwuDJoF8uvg7MWU5
: y
us-central-1.tardigrade.io:7777 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S 0.00% N N/A
2020-02-27T10:56:32.793+0545 INFO Node ID: 12CQfR2oQBwFK3k1QjXFSjaP5ZjpNws2zxWRwuDJoF8uvg7MWU5
: y
C:\Users\dhiwa>
Now what should I do?
Should I just be online, until the GE is done?
How should I check the status?
Would there be any data left on my hard disk drive after the GE is done or not?
You can try to exit only on satellite that didn’t disqualify your node. Enter that name when prompted. I think that’s europe and stefan satellites.
Please read the guide, your questions are already answered in that post.
