My node (windows server 2022 standard) constantly gets error ERROR contact:service ping satellite failed and my node dashboard on public ip shows refused to connect. I’ve checked the port forwarding and I’ve tried to run a python http server, which showed on public ip witn no problems. Please help me
I’ve changed port 29000 to 28967, and now the node works, but the dashboard is still not forwarded.
by default 14002 is on local host, you need to setup it on localip:14002 in config
dashboard setup row is by default commented
I was able to solve both of the issues. Thank you all
