Hi everyone,
I’m here asking you for help because my node is behaving weirdly after being suspended. First here’s the full story.
I had two nodes back at home and decided to bring one with me when I moved for uni. What I didn’t realize is that my internet connection was behind a NAT so no port forwarding. I called up my network provider and they gave me a public IP straight away and for free so that was good. However it did take me the better part of a month to get it done so the node got suspended.
I now have restarted the node, got emails that I was suspended on all satellites which was to be expected. However I’m now getting traffic only from one satellite (ap1) and nothing from the others. I’ll attach the logs of the first time I started the node back up (without a public IP so no traffic) and after figuring out the port forwarding.
Before port forwarding
2021-09-06T19:44:02.859Z FATAL Unrecoverable error {"error": "storagenode configuration already exists (/app/config)"}
2021-09-06T19:51:09.643Z INFO Configuration loaded {"Location": "/app/config/config.yaml"}
2021-09-06T19:51:09.904Z INFO Operator email {"Address": "gaby29999@gmail.com"}
2021-09-06T19:51:09.904Z INFO Operator wallet {"Address": "*****"}
2021-09-06T19:51:10.472Z INFO Telemetry enabled {"instance ID": "*****"}
2021-09-06T19:51:10.995Z INFO db.migration Database Version {"version": 53}
2021-09-06T19:51:11.667Z WARN trust Failed to fetch URLs from source; used cache {"source": "https://www.storj.io/dcs-satellites", "error": "HTTP source: Get \"https://www.storj.io/dcs-satellites\": x509: certificate has expir>
2021-09-06T19:51:11.681Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock.
2021-09-06T19:51:31.689Z ERROR preflight:localtime unable to get satellite system time {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "error": "rpc: dial tcp 35.202.157.8:7777: i/o timeout", "errorVe>
2021-09-06T19:51:31.689Z ERROR preflight:localtime unable to get satellite system time {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "error": "rpc: dial tcp 34.102.123.130:7777: i/o timeout", "errorV>
2021-09-06T19:51:31.689Z ERROR preflight:localtime unable to get satellite system time {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "error": "rpc: dial tcp 34.123.107.76:7777: i/o timeout", "errorVe>
2021-09-06T19:51:31.690Z ERROR preflight:localtime unable to get satellite system time {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "error": "rpc: dial tcp 34.141.33.112:7777: i/o timeout", "errorV>
2021-09-06T19:51:31.690Z ERROR preflight:localtime unable to get satellite system time {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "error": "rpc: dial tcp 34.92.229.119:7777: i/o timeout", "errorV>
2021-09-06T19:51:31.690Z ERROR preflight:localtime unable to get satellite system time {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "error": "rpc: dial tcp 34.88.199.144:7777: i/o timeout", "errorV>
2021-09-06T19:51:31.690Z ERROR Failed preflight check. {"error": "system clock is out of sync: system clock is out of sync with all trusted satellites", "errorVerbose": "system clock is out of sync: system clock is out of sync with >
2021-09-06T19:51:32.821Z FATAL Unrecoverable error {"error": "system clock is out of sync: system clock is out of sync with all trusted satellites", "errorVerbose": "system clock is out of sync: system clock is out of sync with >
2021-09-06T19:51:40.818Z INFO Configuration loaded {"Location": "/app/config/config.yaml"}
After port forwarding
2021-11-06T17:55:15.335Z FATAL Unrecoverable error {"error": "Error creating tables for master database on storagenode: migrate: sql: transaction has already been committed or rolled back\n\tstorj.io/private/dbutil/txutil.WithTx>
2021-11-17T13:38:03.378Z INFO Configuration loaded {"Location": "/app/config/config.yaml"}
2021-11-17T13:38:03.435Z INFO Operator email {"Address": "gaby29999@gmail.com"}
2021-11-17T13:38:03.435Z INFO Operator wallet {"Address": "*****"}
2021-11-17T13:38:04.190Z INFO Telemetry enabled {"instance ID": "*****"}
2021-11-17T13:38:04.271Z INFO db.migration Database Version {"version": 53}
2021-11-17T13:38:05.035Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock.
2021-11-17T13:38:05.775Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock.
2021-11-17T13:38:05.776Z INFO bandwidth Performing bandwidth usage rollups
2021-11-17T13:38:05.776Z INFO trust Scheduling next refresh {"after": "3h16m3.250616407s"}
2021-11-17T13:38:05.776Z INFO Node ***** started
2021-11-17T13:38:05.781Z INFO Public server started on [::]:28967
2021-11-17T13:38:05.781Z INFO Private server started on 127.0.0.1:7778
2021-11-17T13:38:06.969Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "VRO2NX4GSWM7S5G3PPR62BHSR26U2IZZ7UJ2KSU4ROSUTPRFJWNQ"}
2021-11-17T13:38:07.048Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "K7UL7BCT3IKQHRIVDEX66L45TZKXGIYFXF6VW2GG6FNBFGAVXVQQ"}
2021-11-17T13:38:07.126Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "WRHLV3QZHMIJFYBE32SNWG4YUXEFSTVJQ264ZIS4QOWA3LUOZAMA"}
2021-11-17T13:38:07.154Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "XGSDLFLKKI5LRJ57BIPANDZVCPBZHL7WH6HZ4UBQZKBZ4Z52EQLQ"}
2021-11-17T13:38:07.289Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "YQGEHIA2WWXLTJVQ5NXMBTXAKOQ5TF4VKNFVXVGSNE5MYHN7IO3Q"}
2021-11-17T13:38:07.354Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "MFIOFY4HJUDXWJIHTXTAY74XF5GBJ4RVD2PB5YRHYTEY6BNKQRHQ"}
2021-11-17T13:38:07.489Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "IAIFNTBZPD5UP57QSQRKB2YQJY76KUQRJJEFMXEYOL4MHQWTJESQ"}
2021-11-17T13:38:07.522Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "C4GF6D7CX6PYFVN725BI4VKOYSQAPQOX7DH6BIUPIRKPCQWNEAJQ"}
LOTS OF DELETE EXPIRED
2021-11-17T13:38:11.046Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "2KLY2MK7NCEFWXICIEW4TEKSRRSMMKKPRWRCJVSOOTQ4BIVP3WLQ"}
2021-11-17T13:38:11.068Z WARN contact:service Your node is still considered to be online but encountered an error. {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Error": "contact: failed to dial storage>
2021-11-17T13:38:11.100Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "ODH3U5LR6MX6QZX32P6LJWK6O4XAGXIBJP2YYZDKV6FBEBGFONUA"}
2021-11-17T13:38:11.103Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "VR7IGUZI6BLAG6ZEYU3NBOQC64H5INHNNNJJ2TKKEZN2IKR5S4WQ"}
2021-11-17T13:38:11.122Z WARN contact:service Your node is still considered to be online but encountered an error. {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Error": "contact: failed to dial storage>
2021-11-17T13:38:11.156Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "N66L5ZRR3JOR5BHIZI7DJVNDM6C72PZ4LNOFXES5VA75TUFZ2PPA"}
2021-11-17T13:38:11.175Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "MQDVSPPXQBF2M47VYIQ57W6ECPPIR4QWBAUOJOX5VTPXJP6B6CQA"}
2021-11-17T13:38:11.237Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "F6TYZ3RWVM7IAI4LNYPNOES34R4WB2Q45AAPAECLJC44REL3GI5A"}
2021-11-17T13:38:11.259Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "CN3EJYPZZA3GWRMAVVJ2B7EA4XPEXXO6KDBKC7EMBRPMZENPYXXQ"}
2021-11-17T13:38:11.277Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "O4SQTE5CVGOMIPOWOUHF26O3PNRVVSMQYV6KDBEN34FR5F4OXTCA"}
2021-11-17T13:38:11.358Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "2AQMCE5KRTRONTM3JTI2KIMLOYA7G4P3UQIWCIINODMVR3HFY2PA"}
2021-11-17T13:38:11.493Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "MTPTQ2JFRPGLFEK4QVIU4I6JOQ6UEW2EZJVD5NDHEIMPI4TDNE2Q"}
2021-11-17T13:38:11.540Z WARN contact:service Your node is still considered to be online but encountered an error. {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "Error": "contact: failed to dial storage >
2021-11-17T13:38:11.606Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "VINEUFCZ42SORPXTXNBRU4LH6I26GUTVTZDVGJR6QAXUKRAG4YXQ"}
2021-11-17T13:38:11.676Z WARN contact:service Your node is still considered to be online but encountered an error. {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Error": "contact: failed to dial storage>
2021-11-17T13:38:11.712Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "DNNYANA2WF4WGCIZNMSXR322Y7OFQFPQ327LG566H3GXEZFIO3RQ"}
2021-11-17T13:38:11.734Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "ZEIURWMLD6TLCGEAX6BQFLOVU5RJDSCPC6HZQQAPSJDOSNBZH6FQ"}
2021-11-17T13:38:11.740Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "UYB3KX4BN62Z6QM72D6FDAK4T46LFQJQEKIEOHVYKEJHHEVIABMA"}
2021-11-17T13:38:11.812Z WARN contact:service Your node is still considered to be online but encountered an error. {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Error": "contact: failed to dial storage >
2021-11-17T13:38:12.725Z WARN contact:service Your node is still considered to be online but encountered an error. {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Error": "contact: failed to dial storage>
2021-11-17T13:38:12.778Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "DUX6GL4JVVPOYOPDNFNY6IL7NUHQTLAEXERH4QHPXZGV2JRVWTMQ"}
2021-11-17T13:38:18.191Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "45NUP7U5TW665MC7LIMFQCRP7YN657KE3JPCUR2QEWPQHMMZRL7Q"}
2021-11-17T13:38:18.194Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "FN3PX4Y73B7CQ7N5WPSKKV5SHS3QSMMHYW6NSBJWGMNQRGMWS3FQ"}
2021-11-17T13:38:18.247Z INFO orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs sending {"count": 187}
2021-11-17T13:38:18.247Z INFO orders.12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo sending {"count": 7}
2021-11-17T13:38:18.246Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "KD5CP42GNJEBSXDHOMBUORMYOJGVONATQWNDOY5Q6ZD623TJ2SBA"}
2021-11-17T13:38:18.247Z INFO orders.1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE sending {"count": 25}
2021-11-17T13:38:18.247Z INFO orders.12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB sending {"count": 66}
2021-11-17T13:38:18.247Z INFO orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 sending {"count": 395}
2021-11-17T13:38:18.247Z INFO orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S sending {"count": 2085}
2021-11-17T13:38:18.313Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "FT2Q7YGETEWRWM53SNI4OV5NUXBDWQ6K4NDQU7YWAS6UCFECPOCQ"}
2021-11-17T13:38:18.322Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "AQKGBOQLXZYQC32JAVOP3EMVOXTJV7UJM44RIVFUDQQ3WLROEAWQ"}
2021-11-17T13:38:18.374Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "XJGBISVEBMPYPTAJCEZS43V6SIPKJ3LIPIIAYYF4WWDXLR6DSUSQ"}
2021-11-17T13:38:18.433Z INFO orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs finished
2021-11-17T13:38:18.461Z INFO orders.12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB finished
2021-11-17T13:38:18.663Z INFO orders.12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo finished
2021-11-17T13:38:18.914Z INFO orders.1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE finished
2021-11-17T13:38:19.080Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "CRDUQ6PFO6GJEC5QQPGXJC6MYPOQFUNZKEXO5IN6SUW4ZQHURGZA"}
2021-11-17T13:38:19.202Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "OW3XTQVQMO6CGBLIVVBWXR7OUSMLOIZUF4DHBN5WPSYQZR7LJ5MQ"}
2021-11-17T13:38:19.220Z INFO orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S finished
2021-11-17T13:38:20.188Z INFO orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 finished
2021-11-17T13:38:20.474Z INFO orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs sending {"count": 53}
2021-11-17T13:38:20.474Z INFO orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S sending {"count": 345}
2021-11-17T13:38:20.474Z INFO orders.12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB sending {"count": 49}
2021-11-17T13:38:20.474Z INFO orders.12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo sending {"count": 1}
2021-11-17T13:38:20.474Z INFO orders.1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE sending {"count": 30}
2021-11-17T13:38:20.474Z INFO orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 sending {"count": 49}
2021-11-17T13:38:20.585Z INFO orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs finished
2021-11-17T13:38:20.677Z INFO orders.12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB finished
2021-11-17T13:38:20.854Z INFO orders.12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo finished
2021-11-17T13:38:21.152Z INFO orders.1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE finished
2021-11-17T13:38:21.364Z INFO orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S finished
2021-11-17T13:38:21.400Z INFO orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 finished
2021-11-17T13:38:21.404Z INFO collector delete expired {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "P3RWZXGPKBIKGZKUTFC76KDKM4JSTWKL2BJFYSZN6UVNHNV3DRWQ"}
LOTS OF DELETE EXPIRED AGAIN
2021-11-17T13:39:40.739Z INFO collector collect {"count": 2669}
2021-11-17T13:48:21.372Z INFO Got a signal from the OS: "terminated"
2021-11-17T13:48:21.422Z ERROR pieces:trash emptying trash failed {"error": "pieces error: filestore error: context canceled", "errorVerbose": "pieces error: filestore error: context canceled\n\tstorj.io/storj/storage/filestore>
2021-11-17T13:48:21.466Z ERROR pieces:trash emptying trash failed {"error": "pieces error: filestore error: context canceled", "errorVerbose": "pieces error: filestore error: context canceled\n\tstorj.io/storj/storage/filestore>
2021-11-17T13:48:21.467Z ERROR pieces:trash emptying trash failed {"error": "pieces error: filestore error: context canceled", "errorVerbose": "pieces error: filestore error: context canceled\n\tstorj.io/storj/storage/filestore>
2021-11-17T13:48:21.501Z ERROR piecestore:cache error getting current used space: {"error": "context canceled"}
2021-11-17T13:48:44.503Z INFO Configuration loaded {"Location": "/app/config/config.yaml"}
2021-11-17T13:48:44.561Z INFO Operator email {"Address": "gaby29999@gmail.com"}
2021-11-17T13:48:44.561Z INFO Operator wallet {"Address": "*****"}
2021-11-17T13:48:45.253Z INFO Telemetry enabled {"instance ID": "*****"}
2021-11-17T13:48:45.401Z INFO db.migration Database Version {"version": 53}
2021-11-17T13:48:46.011Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock.
2021-11-17T13:48:46.809Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock.
2021-11-17T13:48:46.809Z INFO Node ***** started
2021-11-17T13:48:46.809Z INFO Public server started on [::]:28967
2021-11-17T13:48:46.809Z INFO Private server started on 127.0.0.1:7778
2021-11-17T13:48:46.810Z INFO trust Scheduling next refresh {"after": "8h39m6.818440478s"}
2021-11-17T13:48:46.811Z INFO bandwidth Performing bandwidth usage rollups
2021-11-17T13:48:51.955Z WARN contact:service Your node is still considered to be online but encountered an error. {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Error": "contact: failed to dial storage>
2021-11-17T13:48:52.145Z WARN contact:service Your node is still considered to be online but encountered an error. {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Error": "contact: failed to dial storage>
2021-11-17T13:48:52.495Z WARN contact:service Your node is still considered to be online but encountered an error. {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "Error": "contact: failed to dial storage >
2021-11-17T13:48:52.615Z WARN contact:service Your node is still considered to be online but encountered an error. {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Error": "contact: failed to dial storage>
2021-11-17T13:48:52.840Z WARN contact:service Your node is still considered to be online but encountered an error. {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Error": "contact: failed to dial storage >
2021-11-17T13:48:53.415Z WARN contact:service Your node is still considered to be online but encountered an error. {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Error": "contact: failed to dial storage>
2021-11-17T13:52:31.998Z INFO Got a signal from the OS: "terminated"
2021-11-17T13:52:32.092Z ERROR piecestore:cache error getting current used space: {"error": "context canceled"}
2021-11-17T13:52:41.211Z ERROR pieces:trash emptying trash failed {"error": "pieces error: context canceled; context canceled; context canceled; context canceled; context canceled; context canceled; context canceled; context ca>
2021-11-17T13:52:43.882Z ERROR pieces:trash emptying trash failed {"error": "pieces error: filestore error: context canceled", "errorVerbose": "pieces error: filestore error: context canceled\n\tstorj.io/storj/storage/filestore>
2021-11-17T13:53:25.265Z INFO Configuration loaded {"Location": "/app/config/config.yaml"}
2021-11-17T13:53:25.289Z INFO Operator email {"Address": "gaby29999@gmail.com"}
2021-11-17T13:53:25.289Z INFO Operator wallet {"Address": "******"}
2021-11-17T13:53:25.920Z INFO Telemetry enabled {"instance ID": "*****"}
2021-11-17T13:53:26.004Z INFO db.migration Database Version {"version": 53}
2021-11-17T13:53:26.545Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock.
2021-11-17T13:53:27.318Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock.
2021-11-17T13:53:27.318Z INFO bandwidth Performing bandwidth usage rollups
2021-11-17T13:53:27.320Z INFO Node ***** started
2021-11-17T13:53:27.320Z INFO Public server started on [::]:28967
2021-11-17T13:53:27.320Z INFO Private server started on 127.0.0.1:7778
2021-11-17T13:53:27.322Z INFO trust Scheduling next refresh {"after": "5h39m57.328225098s"}
2021-11-17T14:53:27.318Z INFO bandwidth Performing bandwidth usage rollups
2021-11-17T15:53:27.319Z INFO bandwidth Performing bandwidth usage rollups
2021-11-17T16:30:25.163Z INFO piecestore download started {"Piece ID": "76TOJPUWA5VVZKAQ4PCUVZQ3XPRUCFFI2AMD5N5HZEX554LIIO4Q", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET"}
2021-11-17T16:30:25.844Z INFO piecestore downloaded {"Piece ID": "76TOJPUWA5VVZKAQ4PCUVZQ3XPRUCFFI2AMD5N5HZEX554LIIO4Q", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET"}
the weird thing is that is was successfully settling orders and deleting pieces for other satellites until the last restart but I didn’t change anything in the config.
Now I just get downloads from ap1 and nothing else.
I just restarted the node and here are the logs since the restart:
2021-11-22T20:46:27.199Z INFO Configuration loaded {"Location": "/app/config/config.yaml"}
2021-11-22T20:46:27.224Z INFO Operator email {"Address": "gaby29999@gmail.com"}
2021-11-22T20:46:27.224Z INFO Operator wallet {"Address": "*****"}
2021-11-22T20:46:27.937Z INFO Telemetry enabled {"instance ID": "*****"}
2021-11-22T20:46:28.019Z INFO db.migration Database Version {"version": 53}
2021-11-22T20:46:28.666Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock.
2021-11-22T20:46:29.367Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock.
2021-11-22T20:46:29.368Z INFO Node ***** started
2021-11-22T20:46:29.368Z INFO Public server started on [::]:28967
2021-11-22T20:46:29.368Z INFO Private server started on 127.0.0.1:7778
2021-11-22T20:46:29.368Z INFO trust Scheduling next refresh {"after": "3h55m3.704248287s"}
2021-11-22T20:46:29.368Z INFO bandwidth Performing bandwidth usage rollups
2021-11-22T20:52:31.176Z INFO piecestore download started {"Piece ID": "RB2SSZMDD4PPYT4VXHPGWV54AZYAQJMTVP7PPDM67CYIHRDAZ3YA", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET"}
2021-11-22T20:52:32.292Z INFO piecestore download canceled {"Piece ID": "RB2SSZMDD4PPYT4VXHPGWV54AZYAQJMTVP7PPDM67CYIHRDAZ3YA", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET"}
2021-11-22T20:53:31.448Z INFO piecestore download started {"Piece ID": "3MKLPGUQDY3XRNL3DTKBIGA5WEYTGLKF7UPTNTJNYQ2E5KAVYH7Q", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET"}
2021-11-22T20:53:31.984Z INFO piecestore downloaded {"Piece ID": "3MKLPGUQDY3XRNL3DTKBIGA5WEYTGLKF7UPTNTJNYQ2E5KAVYH7Q", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET"}
2021-11-22T20:56:16.881Z INFO piecestore download started {"Piece ID": "NRLI7UCPFBTWJIFPAGQ6XID4HANQ2PSEOYFVNXL6HNWLJ4QMJRQQ", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET"}
2021-11-22T20:56:17.282Z INFO piecestore downloaded {"Piece ID": "NRLI7UCPFBTWJIFPAGQ6XID4HANQ2PSEOYFVNXL6HNWLJ4QMJRQQ", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET"}
2021-11-22T21:05:50.893Z INFO piecestore download started {"Piece ID": "3MJQPQNHQN3MYTW7BKUKHDGTKRW2RS4E4KXWQ6S7ZRBVF3UPDO6A", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET"}
2021-11-22T21:05:51.482Z INFO piecestore downloaded {"Piece ID": "3MJQPQNHQN3MYTW7BKUKHDGTKRW2RS4E4KXWQ6S7ZRBVF3UPDO6A", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET"}
2021-11-22T21:20:02.214Z INFO piecestore download started {"Piece ID": "GXRYIGAYFGM5CHTZT4GNT264UKXJH3A67ELH4SIYSJ4JJBZDIIAA", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET"}
2021-11-22T21:20:02.937Z INFO piecestore downloaded {"Piece ID": "GXRYIGAYFGM5CHTZT4GNT264UKXJH3A67ELH4SIYSJ4JJBZDIIAA", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET"}
2021-11-22T21:21:02.098Z INFO piecestore download started {"Piece ID": "47JVHSNZ25BH5GITIRNIW2E4APQK6ZPEI7OTAMQLGJIENRUWWMFA", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET"}
2021-11-22T21:21:02.484Z INFO piecestore downloaded {"Piece ID": "47JVHSNZ25BH5GITIRNIW2E4APQK6ZPEI7OTAMQLGJIENRUWWMFA", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET"}
2021-11-22T21:31:17.720Z INFO piecestore download started {"Piece ID": "VH6QK6YZT3ZN5KQTGT6HVWNF3VNNJNQIKKVULJRV7NWNII4H5PMA", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET"}
2021-11-22T21:31:18.289Z INFO piecestore downloaded {"Piece ID": "VH6QK6YZT3ZN5KQTGT6HVWNF3VNNJNQIKKVULJRV7NWNII4H5PMA", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET"}
2021-11-22T21:33:29.776Z INFO piecestore download started {"Piece ID": "RFUDAZ6R3PPLC46MN2NYEVAAAKZIXQ3MISCQEXGRNS2DJ6KW2AFA", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET"}
2021-11-22T21:33:30.126Z INFO piecestore downloaded {"Piece ID": "RFUDAZ6R3PPLC46MN2NYEVAAAKZIXQ3MISCQEXGRNS2DJ6KW2AFA", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET"}
Also here’s what the dashboard says:
Online score on ap1 has been growing steadily over the last few days.
So if anyone has an idea on what could cause this I’m open for suggestions. I looked around on the forum but didn’t find anything.
Thanks a lot !
