Good morning,
I have some problems with a node with ± 10months.
Suddenly, the node has started to go offline overnight without making any changes to either the node or the network.
I have two nodes in place, one as I say about 10 months and the other 4, so far working perfectly until today.
This is the log that throws me but does not give much information.
2021-04-22T17:08:24.157+0200 ERROR contact:service ping satellite failed {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 5, "error": "ping satellite error: failed to dial storage node (ID: MY_NODE_ID) at address MY_DDNS:28967: rpc: dial tcp 81.0.38.42:28967: i/o timeout", "errorVerbose": "ping satellite error: failed to dial storage node (ID: MY_NODE_ID) at address MY_DDNS:28967: rpc: dial tcp MY_PUBLIC_IP:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
Say that the port and non-IP settings are correct and have not been modified.
I have reinstalled in case it was a version problem but I’m still the same.
Actually i have v1.27.6.
Any ideas?
UPDATE:
I can see this logs too
2021-04-22T17:11:49.987+0200 INFO **Public server started on [::]:28967**
2021-04-22T17:11:49.987+0200 INFO Private server started on 127.0.0.1:7778
2021-04-22T17:11:49.989+0200 ERROR **collector unable to delete piece** {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "B3HHCA6BXDBG3IHNCGYMJREGVG2ROHHORQ4RKNQOOMDPBAPYUWQQ", "error": "pieces error: filestore error: **file does not exist",** "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:99\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:81\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:80\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
