I’m running a Storj node from the Windows GUI [Windows 11] and I’m seeing that my QUIC is supposedly misconfigured. I’ve opened up both tcp and udp port 28967 on my firewall, and forwarded both tcp and udp port 28967 on my router. I’m not sure what else I’m supposed to do… the details from the log file are as follows:
log file
2022-12-13T12:08:56.965-0500 INFO Stop/Shutdown request received.
2022-12-13T12:08:56.965-0500 ERROR contact:service ping satellite failed {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 1, "error": "ping satellite: context canceled", "errorVerbose": "ping satellite: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-13T12:08:56.965-0500 ERROR contact:service ping satellite failed {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 1, "error": "ping satellite: context canceled", "errorVerbose": "ping satellite: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-13T12:08:56.965-0500 INFO contact:service context cancelled {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2022-12-13T12:08:56.965-0500 ERROR contact:service ping satellite failed {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 1, "error": "ping satellite: context canceled", "errorVerbose": "ping satellite: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-13T12:08:56.965-0500 INFO contact:service context cancelled {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo"}
2022-12-13T12:08:56.965-0500 ERROR contact:service ping satellite failed {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 2, "error": "ping satellite: context canceled", "errorVerbose": "ping satellite: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-13T12:08:56.965-0500 INFO contact:service context cancelled {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2022-12-13T12:08:56.965-0500 ERROR contact:service ping satellite failed {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 1, "error": "ping satellite: context canceled", "errorVerbose": "ping satellite: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-13T12:08:56.966-0500 INFO contact:service context cancelled {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2022-12-13T12:08:56.965-0500 ERROR contact:service ping satellite failed {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 1, "error": "ping satellite: context canceled", "errorVerbose": "ping satellite: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-13T12:08:56.965-0500 INFO contact:service context cancelled {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB"}
2022-12-13T12:08:56.966-0500 INFO contact:service context cancelled {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2022-12-13T12:08:59.488-0500 INFO Configuration loaded {"Location": "C:\\Program Files\\Storj\\Storage Node\\config.yaml"}
2022-12-13T12:08:59.488-0500 INFO Anonymized tracing enabled
2022-12-13T12:08:59.490-0500 INFO Operator email {"Address": "-"}
2022-12-13T12:08:59.490-0500 INFO Operator wallet {"Address": "0x9316bA63b1532de05600c2597A21c4B26e10b61F"}
2022-12-13T12:08:59.754-0500 INFO Telemetry enabled {"instance ID": "1vStvrMws5gF3oxWmhUAKmomv8Rx432VgG1p8Z7g1cbZZUWEjX"}
2022-12-13T12:08:59.754-0500 INFO Event collection enabled {"instance ID": "1vStvrMws5gF3oxWmhUAKmomv8Rx432VgG1p8Z7g1cbZZUWEjX"}
2022-12-13T12:08:59.934-0500 INFO db.migration Database Version {"version": 54}
2022-12-13T12:09:01.457-0500 INFO preflight:localtime start checking local system clock with trusted satellites' system clock.
2022-12-13T12:09:02.026-0500 INFO preflight:localtime local system clock is in sync with trusted satellites' system clock.
2022-12-13T12:09:02.026-0500 INFO bandwidth Performing bandwidth usage rollups
2022-12-13T12:09:02.026-0500 INFO Node 1vStvrMws5gF3oxWmhUAKmomv8Rx432VgG1p8Z7g1cbZZUWEjX started
2022-12-13T12:09:02.026-0500 INFO Public server started on [::]:28967
2022-12-13T12:09:02.026-0500 INFO Private server started on 127.0.0.1:7778
2022-12-13T12:09:02.027-0500 INFO trust Scheduling next refresh {"after": "6h43m28.949855412s"}
2022-12-13T12:09:02.158-0500 ERROR contact:service ping satellite failed {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 1, "error": "ping satellite: check-in ratelimit: node rate limited by id", "errorVerbose": "ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-13T12:19:02.203-0500 ERROR contact:service ping satellite failed {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 1, "error": "ping satellite: failed to ping storage node, your node indicated error code: 4, rpc: tcp connector failed: rpc: context deadline exceeded", "errorVerbose": "ping satellite: failed to ping storage node, your node indicated error code: 4, rpc: tcp connector failed: rpc: context deadline exceeded\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:145\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-13T12:19:02.279-0500 ERROR contact:service ping satellite failed {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 1, "error": "ping satellite: failed to ping storage node, your node indicated error code: 4, rpc: tcp connector failed: rpc: context deadline exceeded", "errorVerbose": "ping satellite: failed to ping storage node, your node indicated error code: 4, rpc: tcp connector failed: rpc: context deadline exceeded\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:145\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-13T12:19:02.334-0500 ERROR contact:service ping satellite failed {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 1, "error": "ping satellite: failed to ping storage node, your node indicated error code: 4, rpc: tcp connector failed: rpc: context deadline exceeded", "errorVerbose": "ping satellite: failed to ping storage node, your node indicated error code: 4, rpc: tcp connector failed: rpc: context deadline exceeded\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:145\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-13T12:19:02.407-0500 ERROR contact:service ping satellite failed {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 1, "error": "ping satellite: failed to ping storage node, your node indicated error code: 4, rpc: tcp connector failed: rpc: context deadline exceeded", "errorVerbose": "ping satellite: failed to ping storage node, your node indicated error code: 4, rpc: tcp connector failed: rpc: context deadline exceeded\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:145\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-13T12:19:02.653-0500 ERROR contact:service ping satellite failed {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 1, "error": "ping satellite: failed to ping storage node, your node indicated error code: 4, rpc: tcp connector failed: rpc: context deadline exceeded", "errorVerbose": "ping satellite: failed to ping storage node, your node indicated error code: 4, rpc: tcp connector failed: rpc: context deadline exceeded\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:145\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-13T12:19:03.287-0500 ERROR contact:service ping satellite failed {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 2, "error": "ping satellite: failed to ping storage node, your node indicated error code: 4, rpc: tcp connector failed: rpc: context deadline exceeded", "errorVerbose": "ping satellite: failed to ping storage node, your node indicated error code: 4, rpc: tcp connector failed: rpc: context deadline exceeded\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:145\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-13T12:21:12.226-0500 ERROR contact:service ping satellite failed {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 3, "error": "ping satellite: context canceled", "errorVerbose": "ping satellite: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-13T12:21:12.226-0500 ERROR contact:service ping satellite failed {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 2, "error": "ping satellite: context canceled", "errorVerbose": "ping satellite: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-13T12:21:12.226-0500 ERROR contact:service ping satellite failed {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 2, "error": "ping satellite: context canceled", "errorVerbose": "ping satellite: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-13T12:21:12.226-0500 ERROR contact:service ping satellite failed {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 2, "error": "ping satellite: context canceled", "errorVerbose": "ping satellite: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-13T12:21:12.226-0500 ERROR contact:service ping satellite failed {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 2, "error": "ping satellite: context canceled", "errorVerbose": "ping satellite: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-13T12:21:12.236-0500 ERROR contact:service ping satellite failed {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 2, "error": "ping satellite: context canceled", "errorVerbose": "ping satellite: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-13T12:21:15.460-0500 INFO piecestore upload started {"Piece ID": "WG2CG2F7U6ATBCE7ZBLILZDNB2M7KQAQ5AHDE6KWVSRCVMWCENYQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 999996984064}
2022-12-13T12:21:16.783-0500 INFO piecestore upload started {"Piece ID": "GNXRFXQZVBS5C4DE3QFU747FCOVQRNDUCJIN3X3UXG4Z5VYPS7UQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 999996984064}
2022-12-13T12:21:17.495-0500 INFO piecestore uploaded {"Piece ID": "GNXRFXQZVBS5C4DE3QFU747FCOVQRNDUCJIN3X3UXG4Z5VYPS7UQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Size": 2319360}
