I have setup storj and it states that it is online, however, it states that QUIC is misconfigured.
I know the IP is correct as I am remote hosting into the device using the same IP address given to storj.
I have port forwarded tcp/udp 28967 and multiple services report both the TCP and UDP ports to be open (e.g. https://www.yougetsignal.com/tools/open-ports/)
logs
2022-04-01T21:07:22.642+0100 INFO Configuration loaded {"Location": "C:\\Program Files\\Storj\\Storage Node\\config.yaml"}
2022-04-01T21:07:22.643+0100 INFO Operator email {"Address": "redacted"}
2022-04-01T21:07:22.644+0100 INFO Operator wallet {"Address": "redacted"}
2022-04-01T21:07:23.139+0100 INFO Telemetry enabled {"instance ID": "12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf"}
2022-04-01T21:07:23.152+0100 INFO db.migration Database Version {"version": 53}
2022-04-01T21:07:23.273+0100 INFO preflight:localtime start checking local system clock with trusted satellites' system clock.
2022-04-01T21:07:23.769+0100 INFO preflight:localtime local system clock is in sync with trusted satellites' system clock.
2022-04-01T21:07:23.769+0100 INFO Node 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf started
2022-04-01T21:07:23.769+0100 INFO Public server started on [::]:28967
2022-04-01T21:07:23.769+0100 INFO Private server started on 127.0.0.1:7778
2022-04-01T21:07:24.002+0100 INFO piecestore upload started {"Piece ID": "MYJHJATZQ4X7VNJ32SAMVXXEMEQEMXY37SWIMNEDDRST7MPXRMFA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 1699974167296}
2022-04-01T21:07:24.002+0100 INFO piecestore upload started {"Piece ID": "NELURALDZAROUHV4HGWOZ2UETTSNPESCLK5BY2ZCWZENBFPGLLEA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 1699974167296}
2022-04-01T21:07:24.009+0100 INFO piecestore uploaded {"Piece ID": "NELURALDZAROUHV4HGWOZ2UETTSNPESCLK5BY2ZCWZENBFPGLLEA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Size": 25600}
2022-04-01T21:07:25.201+0100 INFO piecestore uploaded {"Piece ID": "MYJHJATZQ4X7VNJ32SAMVXXEMEQEMXY37SWIMNEDDRST7MPXRMFA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Size": 1623552}
2022-04-01T21:07:29.068+0100 WARN contact:service failed PingMe request to satellite {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "error": "ping satellite: check-in network: failed to ping node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address: redacted:28967, err: contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: check-in network: failed to ping node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address: redacted:28967, err: contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).requestPingMeOnce:194\n\tstorj.io/storj/storagenode/contact.(*Service).RequestPingMeQUIC:167\n\tstorj.io/storj/storagenode.(*Peer).addConsoleService:841\n\tstorj.io/storj/storagenode.(*Peer).Run:880\n\tmain.cmdRun:251\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:61\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-04-01T21:07:29.520+0100 INFO piecestore upload started {"Piece ID": "TXBRRTKCKEXWWM3OOBVLP5YBIJDBGD3CFUP2EQMG7RSV7EX42FGQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT_REPAIR", "Available Space": 1699972517120}
2022-04-01T21:07:29.533+0100 INFO piecestore uploaded {"Piece ID": "TXBRRTKCKEXWWM3OOBVLP5YBIJDBGD3CFUP2EQMG7RSV7EX42FGQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT_REPAIR", "Size": 18688}
2022-04-01T21:07:32.010+0100 INFO piecestore upload started {"Piece ID": "VCEW4RS6SHED7X7IQ4DACYJTRJLZR73SYU46424LNNTZDUSYVZ3Q", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 1699972497920}
2022-04-01T21:07:32.105+0100 INFO piecestore uploaded {"Piece ID": "VCEW4RS6SHED7X7IQ4DACYJTRJLZR73SYU46424LNNTZDUSYVZ3Q", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Size": 32512}
2022-04-01T21:07:34.734+0100 WARN contact:service failed PingMe request to satellite {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "error": "ping satellite: check-in network: failed to ping node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address: redacted:28967, err: contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: check-in network: failed to ping node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address: redacted:28967, err: contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).requestPingMeOnce:194\n\tstorj.io/storj/storagenode/contact.(*Service).RequestPingMeQUIC:167\n\tstorj.io/storj/storagenode.(*Peer).addConsoleService:841\n\tstorj.io/storj/storagenode.(*Peer).Run:880\n\tmain.cmdRun:251\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:61\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-04-01T21:07:39.998+0100 WARN contact:service failed PingMe request to satellite {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "error": "ping satellite: check-in network: failed to ping node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address: redacted:28967, err: contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: check-in network: failed to ping node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address: redacted:28967, err: contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).requestPingMeOnce:194\n\tstorj.io/storj/storagenode/contact.(*Service).RequestPingMeQUIC:167\n\tstorj.io/storj/storagenode.(*Peer).addConsoleService:841\n\tstorj.io/storj/storagenode.(*Peer).Run:880\n\tmain.cmdRun:251\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:61\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-04-01T21:07:43.914+0100 INFO piecestore upload started {"Piece ID": "XGONSJIZSML7UK6RAWINSJ4CMHBOTCCFMOLLST5LLROUTXX7JOCA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 1699972464896}
2022-04-01T21:07:44.007+0100 INFO piecestore uploaded {"Piece ID": "XGONSJIZSML7UK6RAWINSJ4CMHBOTCCFMOLLST5LLROUTXX7JOCA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Size": 24832}
2022-04-01T21:07:45.384+0100 WARN contact:service failed PingMe request to satellite {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "error": "ping satellite: check-in network: failed to ping node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address: redacted:28967, err: contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: check-in network: failed to ping node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address: redacted:28967, err: contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).requestPingMeOnce:194\n\tstorj.io/storj/storagenode/contact.(*Service).RequestPingMeQUIC:167\n\tstorj.io/storj/storagenode.(*Peer).addConsoleService:841\n\tstorj.io/storj/storagenode.(*Peer).Run:880\n\tmain.cmdRun:251\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:61\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-04-01T21:07:47.954+0100 INFO piecestore upload started {"Piece ID": "QLJVTL65QDGQ525MXIF3V2SRA6N66CLSGLS75UIIHDW4NX4BTLTA", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "PUT", "Available Space": 1699972439552}
2022-04-01T21:07:47.958+0100 INFO piecestore uploaded {"Piece ID": "QLJVTL65QDGQ525MXIF3V2SRA6N66CLSGLS75UIIHDW4NX4BTLTA", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "PUT", "Size": 768}
2022-04-01T21:07:50.735+0100 WARN contact:service failed PingMe request to satellite {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "error": "ping satellite: check-in network: failed to ping node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address: redacted:28967, err: contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: check-in network: failed to ping node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address: redacted:28967, err: contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).requestPingMeOnce:194\n\tstorj.io/storj/storagenode/contact.(*Service).RequestPingMeQUIC:167\n\tstorj.io/storj/storagenode.(*Peer).addConsoleService:841\n\tstorj.io/storj/storagenode.(*Peer).Run:880\n\tmain.cmdRun:251\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:61\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-04-01T21:07:54.464+0100 INFO piecestore upload started {"Piece ID": "F64RCIX6UFTGWK3WPM5DZPNGBSF7LBHSBGCKLBXZ6P47WNJ47FEQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 1699972438272}
2022-04-01T21:07:54.558+0100 INFO piecestore uploaded {"Piece ID": "F64RCIX6UFTGWK3WPM5DZPNGBSF7LBHSBGCKLBXZ6P47WNJ47FEQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Size": 13056}
2022-04-01T21:07:55.974+0100 WARN contact:service failed PingMe request to satellite {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "error": "ping satellite: check-in network: failed to ping node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address: redacted:28967, err: contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: check-in network: failed to ping node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address: redacted:28967, err: contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).requestPingMeOnce:194\n\tstorj.io/storj/storagenode/contact.(*Service).RequestPingMeQUIC:167\n\tstorj.io/storj/storagenode.(*Peer).addConsoleService:841\n\tstorj.io/storj/storagenode.(*Peer).Run:880\n\tmain.cmdRun:251\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:61\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-04-01T21:07:55.974+0100 WARN failed QUIC check {"error": "ping satellite: failed to ping storage node using QUIC: ping satellite: check-in network: failed to ping node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address: redacted:28967, err: contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: failed to ping storage node using QUIC: ping satellite: check-in network: failed to ping node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address: redacted:28967, err: contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).RequestPingMeQUIC:176\n\tstorj.io/storj/storagenode.(*Peer).addConsoleService:841\n\tstorj.io/storj/storagenode.(*Peer).Run:880\n\tmain.cmdRun:251\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:61\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-04-01T21:07:55.974+0100 INFO bandwidth Performing bandwidth usage rollups
2022-04-01T21:07:55.974+0100 INFO trust Scheduling next refresh {"after": "3h45m26.346986721s"}
2022-04-01T21:07:56.918+0100 INFO piecestore upload started {"Piece ID": "5OFVKDNJQ7DKSGWY72VT6UFUNSXJFUKLXLEHOQM7RR3UNKVNG73A", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 1699962629120}
2022-04-01T21:07:57.010+0100 INFO piecestore uploaded {"Piece ID": "5OFVKDNJQ7DKSGWY72VT6UFUNSXJFUKLXLEHOQM7RR3UNKVNG73A", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Size": 16384}
2022-04-01T21:08:01.073+0100 INFO piecestore upload started {"Piece ID": "46C5S3VG7MOV3TFBSXQTJQREZ42NMR66GTQYPQ6YUEB5X2YGXCDA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT_REPAIR", "Available Space": 1699962612224}
2022-04-01T21:08:01.210+0100 INFO piecestore uploaded {"Piece ID": "46C5S3VG7MOV3TFBSXQTJQREZ42NMR66GTQYPQ6YUEB5X2YGXCDA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT_REPAIR", "Size": 36608}
2022-04-01T21:08:01.532+0100 WARN contact:service Your node is still considered to be online but encountered an error. {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Error": "contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity"}
2022-04-01T21:08:01.617+0100 WARN contact:service Your node is still considered to be online but encountered an error. {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "Error": "contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity"}
2022-04-01T21:08:01.632+0100 WARN contact:service Your node is still considered to be online but encountered an error. {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Error": "contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity"}
2022-04-01T21:08:01.823+0100 WARN contact:service Your node is still considered to be online but encountered an error. {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Error": "contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity"}
2022-04-01T21:08:02.064+0100 WARN contact:service Your node is still considered to be online but encountered an error. {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Error": "contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity"}
2022-04-01T21:08:02.639+0100 WARN contact:service Your node is still considered to be online but encountered an error. {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Error": "contact: failed to dial storage node (ID: 12RVTpcCfryn2bmaZvczVvVvUDs4BZyBS1r8nQ8xJZ1Ekrp7brf) at address redacted:28967 using QUIC: rpc: quic: timeout: no recent network activity"}
2022-04-01T21:08:03.788+0100 INFO piecestore upload started {"Piece ID": "OELFLOBOX3PXJLGLSDDEKC7XA7V5J6JCO5BIQKDFLN77J7EO3U3Q", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 1699962575104}
2022-04-01T21:08:03.850+0100 INFO piecestore upload started {"Piece ID": "C3L4KYKN54JPLJLCLDA7CPM65ISNCHE7UQJ3XFFD5A6GWKXOOZJA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT", "Available Space": 1699962575104}
2022-04-01T21:08:03.893+0100 INFO piecestore uploaded {"Piece ID": "C3L4KYKN54JPLJLCLDA7CPM65ISNCHE7UQJ3XFFD5A6GWKXOOZJA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT", "Size": 34304}
2022-04-01T21:08:03.899+0100 INFO piecestore uploaded {"Piece ID": "OELFLOBOX3PXJLGLSDDEKC7XA7V5J6JCO5BIQKDFLN77J7EO3U3Q", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Size": 26624}
2022-04-01T21:08:12.871+0100 INFO piecestore upload started {"Piece ID": "RBS2BUDM2PQ3HAVYA5UK64GLV6SMSHUIA53TP6JBD6GEFGEDI3XQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 1699962513152}
2022-04-01T21:08:12.875+0100 INFO piecestore uploaded {"Piece ID": "RBS2BUDM2PQ3HAVYA5UK64GLV6SMSHUIA53TP6JBD6GEFGEDI3XQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Size": 8192}
2022-04-01T21:08:14.562+0100 INFO piecestore upload started {"Piece ID": "QFWPFHB3OBH6QB6AZRNTJBB2KKQI2JCWXZZD2ZIF2KCZAUUO3VIA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 1699962504448}
2022-04-01T21:08:14.658+0100 INFO piecestore uploaded {"Piece ID": "QFWPFHB3OBH6QB6AZRNTJBB2KKQI2JCWXZZD2ZIF2KCZAUUO3VIA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Size": 18688}
