Hello.
In this soft you can check your node stats, it takes info from node API so no difference what node you have, main thing that api is accessibly in local network.
Just add your node to list of nodes you have.
Added some features here, Now it is possible to find node by ID
Search by ID will help if you have lot of nodes, and you get mail that node id is offline, no need to search all of them, which it was.
And it show used space by satellite.
Thank you, this is really cool. Just what I was looking for. I have been playing with it for a bit, but I just found out it doesn’t remember the nodes that I enter after a reboot. Is there a way to ‘store’ my nodes?
Why do you all just install random binaries on your machine? Have you thought about the possible consequences for your storage node, anything else that is running on your system and last but not least any machine connected to your LAN? Am I the only paranoid person in the room?
Hello, new relise of Release 1.8 · TonyTosol/StorJ-Audit (github.com)
Features added Audits are back(last 30 days) Thanks to MaxMaximus on github.
Also added counter How much online, offline, unknown nodes in list for faster overview.
Здравствуйте!
Подскажите, пожалуйста, не работает StorJ Audit v1.8, все данные получает, но все узлы offline. Доступ к узлам по локальной сети есть.
192.168.1.109:14005 - ok
Такая же ошибка на всех узлах.
Что я не сделал?
проверил api
192.168.1.109:14005/api/sno/estimated-payout - ok
192.168.1.109:14005/api/sno - ok
192.168.1.109:14005/api/sno/satellite - ошибка: 404. Something Went Wrong. The page you’re trying to access is either broken, or doesn’t exist
translation
Hello!
Tell me, please, StorJ Audit v1.8 does not work, it receives all data, but all nodes are offline. There is access to the nodes on the local network.
Same error on all nodes.
What didn’t I do?
checked api
192.168.1.109:14005/api/sno/satellite - error: 404. Something Went Wrong. The page you’re trying to access is either broken, or doesn’t exist
On proverjaet v api Lastcontact, esli on bolshe 2 minut to pishet 4to offline, berjot vremja s kompjutera na kotorom vy sami za osnovu, mozhet u vas raznitsa vo vremjani na kakom-to komjutere proverte.
I checked the time and time zone, they are identical.
All nodes on win10.
Launched StorJ Audit 1.8 locally, on the node.
With any addition of a host, everything is offline - 192.168.1.109:14005, 127.0.0.1:14005, localhost:14005
This is a screenshot of version 1.7.1, apparently everything is in order here.
есть, на ПК где запускается StorJ Audit, изменил формат даты с европейской на американскую, заработало!
конечно не удобно, но это не проблема, все работает.
спасибо!
translation
yes, on the PC where StorJ Audit is launched, I changed the date format from European to American, it worked!
Of course it’s not convenient, but it’s not a problem, everything works.
Thank you!
