Satellite specific usage information post v1.122.1
Hi all,
I wonder if anyone has found any API’s that allow to find the values being held in storage by each satellite as it used to be in the API ?
example:
# wget -O - http://localhost:14002/api/sno/satellite/12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs | jq '.storageSummary'
--2025-02-20 02:08:40--  http://localhost:14002/api/sno/satellite/12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs
Resolving localhost (localhost)... ::1, 127.0.0.1
Connecting to localhost (localhost)|::1|:14002... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/json]
Saving to: 'STDOUT'
-                                 [ <=>                                              ]  10.71K  --.-KB/s    in 0s
2025-02-20 02:08:40 (318 MB/s) - written to stdout [10969]
948294511753518.6
You may see other info
To get a list of satellites:
wget -O - http://localhost:14002/api/sno | jq '.satellites[].id' -r
I’m looking for this value :
currentStorageUsed
Looks to be removed by this patch: https://review.dev.storj.io/c/storj/storj/+/16040
Commit message explains the challenges, why it is removed.
Looks like piecestore (and also hashstore) share the information via the prometheus compatible metrics endpoint:
http://localhost:30009/metrics (30009 is my debug port)
blobs_usage{satellite="_12whfK1EDvHJtajBiAUeajQLYcWqxcQmdYQU5zX5cCf6bAxfgu4",scope="storj_io_storj_storagenode_pieces",field="total_size"} 5.791104e+07
blobs_usage{satellite="_12whfK1EDvHJtajBiAUeajQLYcWqxcQmdYQU5zX5cCf6bAxfgu4",scope="storj_io_storj_storagenode_pieces",field="content_size"} 5.788288e+07
Where is the debug port located by default?
Random port, I think:
$ storagenode --help --defaults=release| grep debug        0 [11:10:09]
      --debug.addr string                 address to listen on for debug endpoints (default "127.0.0.1:0")
It’s better to add explicit configuration.
I have this one:
debug.addr: localhost:30009
You may find it by netstat -l
hmm
$ curl localhost:34267
404: Page Not Found
Think i found it … - but i can’t seem to get data out of it
metrics are under /metrics
Normal root context should return with a list of available endpoints.
I am not sure if you found the debug port…
Sorry, - i mis-understood i think… i thought it was publishing a port by default locally - however doesnt seem to be the case then
Got it ! obviously forgot also to open the port from docker :slight_smile:
… I shall have a play :slight_smile:
@elek
I dont seem to find this :expressionless:
There is no blobs_usage in recent versions (at least with dedicated disk and no filewalkers on), but there is satellite_usage, which shows what sat thinks you have.
The reports are however hit and miss lately.
# TYPE satellite_usage gauge
satellite_usage{satellite="_1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE",scope="storj_io_storj_storagenode_nodestats",field="used_bytes"} 2.3688123136e+10
satellite_usage{satellite="_121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6",scope="storj_io_storj_storagenode_nodestats",field="used_bytes"} -0
satellite_usage{scope="storj_io_storj_storagenode_nodestats",satellite="_12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S",field="used_bytes"} 6.455309131776e+12
satellite_usage{satellite="_12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs",scope="storj_io_storj_storagenode_nodestats",field="used_bytes"} 4.0745021765128145e+12
is that on the /metrics - endpoint?
I just have this under that endpoint
# TYPE function gauge
function{name="root",scope="storj_io_common_process",field="current"} 1
function{name="root",scope="storj_io_common_process",field="highwater"} 1
function{name="root",scope="storj_io_common_process",field="successes"} 0
function{name="root",scope="storj_io_common_process",field="errors"} 0
function{name="root",scope="storj_io_common_process",field="panics"} 0
function{name="root",scope="storj_io_common_process",field="failures"} 0
function{name="root",scope="storj_io_common_process",field="total"} 0
function{name="root",scope="storj_io_common_process",field="delta"} 0
function{name="__Client__All",scope="storj_io_storj_private_version_checker",field="current"} 0
function{name="__Client__All",scope="storj_io_storj_private_version_checker",field="highwater"} 1
function{name="__Client__All",scope="storj_io_storj_private_version_checker",field="successes"} 5
function{name="__Client__All",scope="storj_io_storj_private_version_checker",field="errors"} 0
function{name="__Client__All",scope="storj_io_storj_private_version_checker",field="panics"} 0
function{scope="storj_io_storj_private_version_checker",name="__Client__All",field="failures"} 0
function{scope="storj_io_storj_private_version_checker",name="__Client__All",field="total"} 5
function{name="__Client__All",scope="storj_io_storj_private_version_checker",field="delta"} 4
# TYPE function_times gauge
function_times{name="root",kind="success",scope="storj_io_common_process",field="count"} 0
function_times{name="root",kind="failure",scope="storj_io_common_process",field="count"} 0
function_times{scope="storj_io_storj_private_version_checker",name="__Client__All",kind="success",field="count"} 5
function_times{name="__Client__All",kind="success",scope="storj_io_storj_private_version_checker",field="sum"} 2.129042113
function_times{name="__Client__All",kind="success",scope="storj_io_storj_private_version_checker",field="min"} 0.380473731
function_times{scope="storj_io_storj_private_version_checker",name="__Client__All",kind="success",field="max"} 0.513622254
function_times{name="__Client__All",kind="success",scope="storj_io_storj_private_version_checker",field="rmin"} 0.380473728
function_times{scope="storj_io_storj_private_version_checker",name="__Client__All",kind="success",field="ravg"} 0.425808448
function_times{name="__Client__All",kind="success",scope="storj_io_storj_private_version_checker",field="r10"} 0.382409497
function_times{name="__Client__All",kind="success",scope="storj_io_storj_private_version_checker",field="r50"} 0.42080992
function_times{kind="success",name="__Client__All",scope="storj_io_storj_private_version_checker",field="r90"} 0.479702572
function_times{scope="storj_io_storj_private_version_checker",name="__Client__All",kind="success",field="r99"} 0.510230273
function_times{name="__Client__All",kind="success",scope="storj_io_storj_private_version_checker",field="rmax"} 0.51362224
function_times{scope="storj_io_storj_private_version_checker",name="__Client__All",kind="success",field="recent"} 0.513622254
function_times{name="__Client__All",kind="failure",scope="storj_io_storj_private_version_checker",field="count"} 0
Correct, you can load it in web browser and see what is in there. Here for example it is on IP 192.168.10.12 and port 9651, so you can just do http://192.168.10.12:9651/metrics.
Here it is over 7000 lines long, yours looks like incomplete.
Try restarting the node. Also after restart it takes a few minutes to show all the metrics.
ooooo
Ok, I will try it on another node
Under 1.122.1
I can see this
# TYPE blobs_usage gauge
blobs_usage{satellite="_1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE",scope="storj_io_storj_storagenode_pieces",field="total_size"} 1.4573824e+07
blobs_usage{satellite="_1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE",scope="storj_io_storj_storagenode_pieces",field="content_size"} 1.4565632e+07
blobs_usage{satellite="_12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs",scope="storj_io_storj_storagenode_pieces",field="total_size"} 1.35677974528e+11
blobs_usage{satellite="_12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs",scope="storj_io_storj_storagenode_pieces",field="content_size"} 1.35480663552e+11
blobs_usage{satellite="_121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6",scope="storj_io_storj_storagenode_pieces",field="total_size"} 3.4527639296e+10
blobs_usage{scope="storj_io_storj_storagenode_pieces",satellite="_121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6",field="content_size"} 3.4381476608e+10
blobs_usage{satellite="_12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S",scope="storj_io_storj_storagenode_pieces",field="total_size"} 2.9018338202e+11
blobs_usage{satellite="_12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S",scope="storj_io_storj_storagenode_pieces",field="content_size"} 2.89510744068e+11
However… - What does the value actually mean?
And this also doesn’t look like JSON so what coding/format would this be , just so i can attempt to collect data from it?
Cheers
:point_up: is scientific notation. The e+07 part means you need to move the decimal 7 places to the right. So the number becomes 14573824. These are bytes of data.
:point_down:
                                                             :point_down:
