Simple tool to assess node performance?
Hello,
Even though I regularly check this forum I do not remember if a simple tool/script to assess the node’s performance is available. Would be interesting to know how a node performs in terms of races won, throughput, etc. and benchmark your results against nodes similar in size, hardware, location, etc. I don’t have time to closely investigate the logs and I guess I’m not the only one in this situation.
Thanks in advance!
Hello @silaxe,
You may try to use
See also
