Slow transmission speed of new node
There is a large difference in transmission speed between nodes that have been started for about a week in other locations and existing nodes. It might be slow because the audit hasn’t finished yet.
I don’t think it was this slow in the beginning when I was running the two existing nodes, but could it be set up incorrectly?
It was recently changed so that only 1% of ingress goes to new nodes.
Wow, then the speed will be that low until the node is verified…!
Recently, there may be a reason why the existing node has a lot of reception volume because there are many customers, but the reception volume that was flowing to the unverified node is merged into the existing node, so the speed seems to be better.
I think it means, “We’ll see if you can stand the test.” :slight_smile:
