Hello, I’ve been trying to get Storj up and running for days but it just doesn’t work. I tried several times to set up Storj again, created a new ID for me, I even tested the whole thing without firewall, but everything didn’t work. I don’t understand why, it worked for 3 days until I had a malfunction at vodafone, the malfunction gin from 3am to 12pm. Since then, it has not worked at all.
Log :
2020-05-04T04:07:22.839+0200 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
2020-05-04T04:07:22.864+0200 INFO tracing disabled
2020-05-04T04:07:22.873+0200 INFO Operator email {“Address”: “XXXX”}
2020-05-04T04:07:22.874+0200 INFO Operator wallet {“Address”: “XXX”}
2020-05-04T04:07:24.314+0200 INFO db.migration Database Version {“version”: 36}
2020-05-04T04:07:25.141+0200 INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2020-05-04T04:07:26.033+0200 INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2020-05-04T04:07:26.033+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T04:07:26.033+0200 INFO trust Scheduling next refresh {“after”: “2h59m18.896706473s”}
2020-05-04T04:07:26.033+0200 INFO Node 1b2Y63b8bsbmaWFyvp7kyrNETW76tGYDb7jJbHwwmFZpNeFPGv started
2020-05-04T04:07:26.033+0200 INFO Public server started on [::]:28967
2020-05-04T04:07:26.033+0200 INFO Private server started on 127.0.0.1:7778
2020-05-04T05:07:43.755+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T06:07:43.757+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T07:07:03.585+0200 INFO trust Scheduling next refresh {“after”: “8h0m58.190888458s”}
2020-05-04T07:07:43.756+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T08:07:43.870+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T09:07:43.757+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T10:07:43.760+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T11:07:43.757+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T12:07:43.757+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T13:07:43.756+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T14:07:43.755+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T15:07:43.757+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T15:08:02.492+0200 INFO trust Scheduling next refresh {“after”: “5h53m17.820399788s”}
2020-05-04T16:07:43.757+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T17:07:43.757+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T18:07:43.756+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T19:07:43.756+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T20:07:43.757+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T21:01:21.303+0200 INFO trust Scheduling next refresh {“after”: “2h52m48.696089299s”}
2020-05-04T21:07:43.756+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T22:07:43.755+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T23:07:43.756+0200 INFO bandwidth Performing bandwidth usage rollups
2020-05-04T23:54:11.243+0200 INFO trust Scheduling next refresh {“after”: “5h41m8.956869166s”}
2020-05-05T00:07:43.757+0200 INFO bandwidth Performing bandwidth usage rollups
