Hey there,
so my storagenode is running for 5 or 6 dayś with no error.
I stoped the node than disconnectet the internet (chance ethernet cable) and then reconnect the PC. after starting the Storagenode again an error like “127.0.0.1 TCP error conn. Error …” showed.
so i stoped the node.
After updating all packetś (also updated docker and docker-ce) i repeated the process.
This time, no “Fatal” error was shown but if i typed in “docker exec …” it typed “Error response from daemon: Container [container_id] is restarting, wait until the container is running”
so i stoped again.
then “docker rm storagenode”
and after that the install command:
docker run -d --restart unless-stopped -p 28967:28967 \
-e WALLET=“0xc2FF990C69A5ce5AC7Fc6e3ce2a11F02C949521e” \
-e EMAIL="email@gmail.com" \
-e ADDRESS=“domain.net:28967” \
-e BANDWIDTH=“200TB” \
-e STORAGE=“3TB” \
–dns=8.8.8.8 \
–mount type=bind,source="/id",destination=/app/identity \
–mount type=bind,source="/data",destination=/app/config \
–name storagenode storjlabs/storagenode:alpha
i added the “–dns” because i read in an article that the TCP error only exists if an error in the dns system exists.
after that i started it with
“docker start storagenode”
and then
“docker exec …”
So my Problem is the container still restarts.
Info:
-Permanently connectet with the internet
-Stored 1,5GB data
-Bandwith Limit doesn´t exist
-Conn. Speed is 70-80 DOWN and 40 to 50 UP
-Newest Version of Storagenode and Watchover
-Port is forwarded
-My ddns is updated
-Read and Write prom. to dir(s) “/id” and “/data”
-run docker and storagenode under ubuntu 19.04
