Storagenode repeated storage/storagenode-update is not executable
I’m still locked in this death spiral of ‘not executable’. I’ve stopped the container, rm’d it, pulled latest, but still the same thing. Directories have r/x, bins have r/x. Uid of dockerlimited is 1028 and is set in the docker run command. I went through the other topic but mine is still in crisis.
drwxrwxrwx+ 7 dockerlimited users 4096 Sep 27 02:19 storage
drwxrwxrwx+ 2 dockerlimited users 4096 Sep 27 03:18 bin
-rwxrwxrwx+ 1 dockerlimited users 78855672 Sep 27 03:18 storagenode
-rwxrwxrwx+ 1 dockerlimited users 32505920 Sep 27 03:18 storagenode-updater
2024-09-27 11:18:49,890 INFO spawnerr: command at ‘/app/config/bin/storagenode’ is not executable
2024-09-27 11:18:49,890 INFO spawnerr: command at ‘/app/config/bin/storagenode-updater’ is not executable
2024-09-27 11:18:50,905 INFO success: processes-exit-eventlistener entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2024-09-27 11:18:50,906 INFO spawnerr: command at ‘/app/config/bin/storagenode’ is not executable
2024-09-27 11:18:50,906 INFO spawnerr: command at ‘/app/config/bin/storagenode-updater’ is not executable
2024-09-27 11:18:52,909 INFO spawnerr: command at ‘/app/config/bin/storagenode’ is not executable
2024-09-27 11:18:52,909 INFO spawnerr: command at ‘/app/config/bin/storagenode-updater’ is not executable
2024-09-27 11:18:55,912 INFO spawnerr: command at ‘/app/config/bin/storagenode’ is not executable
2024-09-27 11:18:55,912 INFO gave up: storagenode entered FATAL state, too many start retries too quickly
2024-09-27 11:18:55,912 INFO spawnerr: command at ‘/app/config/bin/storagenode-updater’ is not executable
2024-09-27 11:18:55,912 INFO gave up: storagenode-updater entered FATAL state, too many start retries too quickly
2024-09-27 11:18:57,915 WARN received SIGQUIT indicating exit request
2024-09-27 11:18:57,915 INFO waiting for processes-exit-eventlistener to die
2024-09-27 11:18:59,918 WARN stopped: processes-exit-eventlistener (terminated by SIGTERM)
Same problem for me, i can’t understand where the problem is.
Now that I typed all that out, it’s working now. Concerned about problems deeper down, I a ran a "sudo chown -R dockerlimited:users * on my storj top dir.
How is the partition mounted? With “noexec”?
Hello @jbew81,
Please, apply x permission to the bin subfolder of your storage location from the source value of the --mount option for /app/config/ in your docker run command, e.g.
sudo chmod +x /mnt/y/storagenode2/bin
Thks Alexey,
Before :
root@NAS:~#ls -l /volume1/my-storj-data/node1/bin/
total 108756
----------+ 1 root root 78855672 Sep 27 01:31 storagenode
----------+ 1 root root 32505920 Sep 27 01:31 storagenode-updater
Change :
root@NAS:~#chmod +x /volume1/my-storj-data/node1/bin/*
After:
total 108756
—x------ 1 root root 78855672 Sep 27 01:31 storagenode
—x------ 1 root root 32505920 Sep 27 01:31 storagenode-updater
Everything is fine now.
Thank you.
Thanks.
This works.
Just to help people who are using docker with generic installation information.
My path is
/volume1/Storj/storage/bin
So the command as provided by Alexey is (for my path)
sudo chmod +x /volume1/Storj/storage/bin
Working fine now.
I had the same issue and it is fixed changing the permissions as indicated above. Still how is this possible all of a sudden for multiple people apparently? Anything to change in the setup to prevent this from happening?
Hello @therealmko,
Welcome back!
Perhaps, more testing on NASes. We do not have them, and the usual setups are ok.
However, I created a PR, which should help to solve this problem:
I just had this happen myself when I was out of town for 3 days. Now one of my NAS is suspended on a satellite. I did get it fixed by deleting the image, redownloading and then reinputting the commands to run. But this is discouraging as my longest running node is now suspended. It’s back up and running now and will heal itself but out of 3 Synology NAS devices local, this one had the problem.
Hello!
I’m new here. I hosted a (test) node off 500Gb and everything is OK. BUT when I edit the config.yaml file to change the line “operator.wallet-features: [‘zksync-era’]” when I restart the Storj hangs with this log:
2024-09-30 14:59:32,351 INFO spawnerr: command at ‘/app/config/bin/storagenode’ is not executable
2024-09-30 14:59:32,352 INFO spawnerr: command at ‘/app/config/bin/storagenode-updater’ is not executable
2024-09-30 14:59:35,355 INFO spawnerr: command at ‘/app/config/bin/storagenode’ is not executable
2024-09-30 14:59:35,355 INFO gave up: storagenode entered FATAL state, too many start retries too quickly
2024-09-30 14:59:35,356 INFO spawnerr: command at ‘/app/config/bin/storagenode-updater’ is not executable
2024-09-30 14:59:35,356 INFO gave up: storagenode-updater entered FATAL state, too many start retries too quickly
2024-09-30 14:59:37,358 WARN received SIGQUIT indicating exit request
2024-09-30 14:59:37,359 INFO waiting for processes-exit-eventlistener to die
2024-09-30 14:59:39,361 WARN stopped: processes-exit-eventlistener (terminated by SIGTERM)
2024-09-30 14:59:48,732 INFO Set uid to user 0 succeeded
2024-09-30 14:59:48,735 INFO RPC interface ‘supervisor’ initialized
2024-09-30 14:59:48,735 INFO supervisord started with pid 1
2024-09-30 14:59:49,738 INFO spawned: ‘processes-exit-eventlistener’ with pid 9
2024-09-30 14:59:49,743 INFO spawnerr: command at ‘/app/config/bin/storagenode’ is not executable
2024-09-30 14:59:49,744 INFO spawnerr: command at ‘/app/config/bin/storagenode-updater’ is not executable
2024-09-30 14:59:50,745 INFO success: processes-exit-eventlistener entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2024-09-30 14:59:50,746 INFO spawnerr: command at ‘/app/config/bin/storagenode’ is not executable
2024-09-30 14:59:50,747 INFO spawnerr: command at ‘/app/config/bin/storagenode-updater’ is not executable
2024-09-30 14:59:52,749 INFO spawnerr: command at ‘/app/config/bin/storagenode’ is not executable
2024-09-30 14:59:52,750 INFO spawnerr: command at ‘/app/config/bin/storagenode-updater’ is not executable
2024-09-30 14:59:55,753 INFO spawnerr: command at ‘/app/config/bin/storagenode’ is not executable
2024-09-30 14:59:55,753 INFO gave up: storagenode entered FATAL state, too many start retries too quickly
2024-09-30 14:59:55,754 INFO spawnerr: command at ‘/app/config/bin/storagenode-updater’ is not executable
2024-09-30 14:59:55,754 INFO gave up: storagenode-updater entered FATAL state, too many start retries too quickly
2024-09-30 14:59:57,755 WARN received SIGQUIT indicating exit request
2024-09-30 14:59:57,756 INFO waiting for processes-exit-eventlistener to die
2024-09-30 14:59:59,758 WARN stopped: processes-exit-eventlistener (terminated by SIGTERM)
2024-09-30 15:00:08,086 INFO Set uid to user 0 succeeded
2024-09-30 15:00:08,109 INFO RPC interface ‘supervisor’ initialized
2024-09-30 15:00:08,110 INFO supervisord started with pid 1
2024-09-30 15:00:09,111 INFO spawned: ‘processes-exit-eventlistener’ with pid 9
2024-09-30 15:00:09,112 INFO spawnerr: command at ‘/app/config/bin/storagenode’ is not executable
2024-09-30 15:00:09,122 INFO spawnerr: command at ‘/app/config/bin/storagenode-updater’ is not executable
2024-09-30 15:00:10,123 INFO success: processes-exit-eventlistener entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2024-09-30 15:00:10,124 INFO spawnerr: command at ‘/app/config/bin/storagenode’ is not executable
2024-09-30 15:00:10,125 INFO spawnerr: command at ‘/app/config/bin/storagenode-updater’ is not executable
Even when I put back the original config.yaml and restarting the service does not work.
Con someone help me?
Not working for me, node is now done for over 2 hours due to this issue popping up on one of my nodes.
Assuming i’ve messed up the syntax of adding the sudo chown +x command into my docker run command but not sure where i’ve gone wrong
chmod. mod, not own.
If you are confused about paths, open shell in your container:
docker exec -it <storagenode contaienr> /bin/sh
and run this there:
chmod -R +x /app/config/bin
yes sorry, chmod +x, didn’t seem to do anything when I just ran it straight from command but after about 10 minutes the node is finally back up again without that error message.
From what I read im meant to be able to incorporate this into --mount of docker run, but docker fails to provide an example of syntax
Yes, it’s just a mount option, you specify it along with a bunch of other mount options
For example,
docker run --mount type=bind,source=/meow,target=/wuff,exec,noatime
ah thanks for that, so I can just add the chmod +x command there it there, cool
No, you can’t. You can’t cram command into bind options. You can specify a mount option that allows exec. mount(8) - Linux manual page
docker cannot do so unfortunately.
invalid argument "type=bind,source=./test-disk,destination=/app/config,exec,noatime" for "--mount" flag: invalid field 'exec' must be a key=value pair
See 'docker run --help'.
Hmm. Their own documentation have similar flags, not passed as key-value pairs. e.g. here, see readonly flag:
https://docs.docker.com/engine/storage/bind-mounts/#use-a-read-only-bind-mount
docker run -d \
 -it \
 --name devtest \
 --mount type=bind,source="$(pwd)"/target,target=/app,readonly \
 nginx:latest
Let me confirm, brb.
