yes, you will get data slowly, when you get 100 audits on each sattelite you will get 100% of data.
there is low ingress trafic now, so it takes time.
try toolbox, it may be tell you whats is wrong
i think it has something to be with the email i used ! … i used the same email that i had prev used on the node that died …no ?
“something to do with…
… and i found the “port thing” on duc
thkz!
no. its not about the email…
i found this on the logs you told me … :
rpc: tls peer certificate verification error: not signed by any CA in the whitelist: CA cert", “errorVerbose”: “ping satellite error: failed to dial storage node
: rpc: tls peer certificate verification error: not signed by any CA in the whitelist: CA cert\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
hummm … ![]()
used a new token and a new email … it works :)! … thkz to all !
