Storj on a Homeassistant
Good morning,
I’m running a Odroid N2+ with home assistant.
This is running 24/7 now I’m looking if it’s possible to run storj on this also?
Have somebody a working installation on a home assistant server?
Here: Odroid HC4 + Armbian, Storj will be just another container image running like home assistant.
You just need an OS installed like Ubuntu or Armbian.
Have the Homeassistant.img installed not in a docker
Does it allow to run docker or binaries?
If it can run docker (I believe you need to install docker first), then you can use our CLI guide: CLI Install - Storj Docs
if it can run a binary, then you can setup and run it as a standalone binary:
If the Home assistant can support run of services, you may configure the storagenode binary to run as a service, see example: storagenode-deb/docs/contributor-guide.md at f51da2cd02c3a90b063f33fd90f4785fc05c78e0 · storj/storagenode-deb · GitHub
See also
