Thx for notification, Up&Running again ![]()
Awesome! Do you know if the “free reported space” number has maybe moved or something? It hasn’t changed in almost a year: even though we have added thousands of new nodes.
Hello again @Arkina . Storjstats.info seems to have lost count of free and used space for some time. Not sure if this is a problem on your end or not.
Either way, thanks for the site!
Hello @EricTheRed123,
Welcome back!
We no longer publish free space information on https://stats.storjshare.io/, so this information is not available on the dashboard.
See
Hey there,
Since this topic opened I have to ask, are there public statics on what is the current network utilization, I understand that this thread doesn’t ask that and is more about preventing of lost segments. Never the less I am curious i am ware of the following sources (I might be possibly blind):
thanks guys
P.S. so far not planing to leave
stats.storjshare.io is the only source. All other public dashboards depend on this one.
It’s online?
Gaps likely because we didn’t update stats.storjshare.io in time and there is no “flat line instead of NULLs” implemented.
There are several opinions, some prefer that it’s better to have gaps (which clearly shows a missing data) than a wrong linear estimation.
Missing free space:
I believe that we will not add this misleading report of free space back
Just a short Info: With all currently ongoing i decided to stop running storjstats.info.
It was a good ride for the last years, but for me the time has come to say goodbye!
Your site was amazing: thank you for running it! The raw numbers Storj put out were cumbersome, so I always had a bookmark to you to see what was going on.
I hope you find a new cool project to start tracking: good luck! ![]()
I guess now everyone who interested in this stat should build their own local dashboard using https://stats.storjshare.io
I could rebuild it for public use, but I really want to see empty space too. (Yes I know numbers could be faked, but that’s not in my interest)
My simple solution is here:
Not so fancy, but it archives the data daily, and shows it.
Data is here:
(As you see, I started it at the beginning of the year)
If you need more graphs, it’s easy to vibecode more.
looks great so far.
i would love a graph with stored data (without select if possible).
timeframe: 1 year
x-axis starting at 0
thank you it is easy and good solution, easy to read.
