Structure needs cleaning
Hi, today there was a power outage and when I start the Node I get this error and it doesn’t start.
It is a 3-year-old node and 12TB of information, I want to do everything possible to recover it.
txh
Error: Error starting master database on storagenode: database: piece_spaced_used opening file “config/storage/piece_spaced_used.db” failed: unable to open database file: structure needs cleaning
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabase:347
storj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:324
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:299
storj.io/storj/storagenode/storagenodedb.OpenExisting:266
main.cmdRun:62
main.newRunCmd.func1:32
storj.io/private/process.cleanup.func1.4:399
storj.io/private/process.cleanup.func1:417
github.com/spf13/cobra.(*Command).execute:852
github.com/spf13/cobra.(*Command).ExecuteC:960
github.com/spf13/cobra.(*Command).Execute:897
storj.io/private/process.ExecWithCustomOptions:113
main.main:30
runtime.main:250
2023-06-14 22:43:17,219 INFO exited: storagenode (exit status 1; not expected)
2023-06-14 22:43:18,221 INFO gave up: storagenode entered FATAL state, too many start retries too quickly
2023-06-14 22:43:18,747 WARN received SIGTERM indicating exit request
2023-06-14 22:43:18,747 INFO waiting for processes-exit-eventlistener, storagenode-updater to die
2023-06-14T22:43:18.749Z INFO Got a signal from the OS: “terminated” {“Process”: “storagenode-updater”}
2023-06-14 22:43:18,750 WARN received SIGQUIT indicating exit request
2023-06-14 22:43:18,753 INFO stopped: storagenode-updater (exit status 0)
2023-06-14 22:43:19,756 INFO stopped: processes-exit-eventlistener (terminated by SIGTERM)
Please use a UPS.
meaning that your filesystem is corrupted. So, before trying to fix a database you need to fix your filesystem first with fsck, the node should be stopped and the disk is unmounted.
In case of xfs you need to use a different procedure, see
After you fix the filesystem, you may check databases and fix them as well.
Ohoh, not another database failing… :frowning:
But seems FS-related indeed.
Hi, can you give me the commands to run fsck ?
umount -A /dev/DISK
e2fsck /dev/DISK # same as fsck.ext4 /dev/DISK
sudo umount /dev/DISK
sudo fsck /dev/DISK
should you use the -y flag on fsck ?
Yes, otherwise you will be prompted for a yes/no to fix any file. -y is a YES to all prompts.
