Vadim
February 19, 2020, 8:58pm
#1
I have both docker and GUI nodes in different paces.
Docker on raspberry pi 3+ , 50/50 connection and GUI on I5 with 100/100 connection.
on docer successful rate is low only 8%
on GUI node successful is OK
but if we whatch do dashboards ammount of data, there is almost no difference.
Raspberry
GUI
Any idea how it can be? where is the truth?
All data mesured by same software.
This is not a valid comparison between GUI and docker if the nodes are running on different hardware in a different physical location
EDIT: I judged too quickly, the ingress data is about the same. That might mean that one node is receiving fewer but larger pieces than the other.
Vadim
February 19, 2020, 9:10pm
#3
@Derkades
if deepe in my data, then you understand that node get almost same data amount but they report different success rates to logs, if difference would be 10-20% i would understand but it is 10 times
Alexey
February 19, 2020, 10:07pm
#4
how much from that ingress is landed on your disk?
Vadim
February 19, 2020, 10:48pm
#5
it is good question, does dashboard show ingress even for canceled uploads?
Vadim
February 19, 2020, 10:51pm
#6
does it posible to get more deteil logs? like how big file was uploaded?
Alexey
February 19, 2020, 10:55pm
#7
of course
You can enable a debug level
adorid
February 20, 2020, 11:33am
#8
With latest update there is full logs with failed uploads, and if compare from logs then this count is very high:
docker logs storagenode 2>&1 | grep “upload failed” -c
19096
docker logs storagenode 2>&1 | grep “uploaded” -c
9454
And this device is not on weak hardware and hdd is attached directly. There is no even network problems as i got speed 700/700mbit
Vadim
February 20, 2020, 2:05pm
#11
it is looks like docker it self working slower
Im curious does docker on linux limit to use 1 core or does it use all cores available to it? Cause I know the gui isnt limited considering it has access to every system resources unlike docker.
Vadim
February 20, 2020, 3:04pm
#13
also docker eat more memory, GUI take 15-20 MB only.
Yeah very interesting find though.
kevink
February 20, 2020, 3:08pm
#15
My successrate on docker actually got higher with the last update. Had 10% before, got 30% now.
Vadim
#16
and about power consuprion my 5node pc, take 75-80W it is about 16w per node with HDD consuption and HDD cooling.
Thats actually pretty good. My 2 nodes are running on a Dell it maxes at around 35watts.
Phillip
August 10, 2020, 7:09pm
#18
How to run Success Rate on Windows GUI…?!
I found only for Docker…
Alexey
August 10, 2020, 7:46pm
#19
I’ve updated the success rate script to include both canceled and failed as separate values. There are now percentages for both as well. I also fixed an issue where critical audit failures weren’t counted as such due to a change in terminology.
The updated script can be found here (For linux, windows version below)
The new output has a lot more info and looks like this
[image]
Please note this screenshot was made on a log from mostly the version prior to the update. This is why there are h…
For the Windows GUI you need to specify the path to the logs.
Phillip
August 10, 2020, 10:17pm
#20
Ok.
Or i try it via Linux on Wndows 10 from the marketplace.
