Hello, I’ve tested the general functionality via CLI of tardigrade. Very stoked this is finally available.
I’m building an app that has two pieces:
- go server
- typescript frontend
Testing the current nodejs lib with bindings to C (https://github.com/utropicmedia/storj-nodejs) didn’t work locally on a mac.
I began working on my own bindings, but seems the C lib requires heavy compiling, and I’m not a fan of building yet more things reliant on node-gyp / C bindings.
Two questions:
- Is there a lib coming that has better functionality for typescript?
- If no, or if it will be a while – is there an API of sorts that would allow non-C-bindings connecting directly to tardigrade?
If these questions are misguided, I’d love to be directed to better docs or suggestions.
thanks!
T
Hi @TrevorJTClarke -
First - what issue did you run into on a mac? (Also, thanks for posting!)
Second - we’re in-flight on a 1.0-compatible version of the nodejs bindings, targeting the end of the week for release. The bindings are downstream from the c library for a few reasons:
- Complexity: libuplink does a LOT of work. Rewriting it doesn’t make sense
- Maintainability: having loosely-coupled bindings increases maintenance overhead drastically
- Performance: the C routines are generally smaller
If you want to connect to Tardigrade without the dependency I would suggest looking at the S3 gateway approach - check out https://documentation.tardigrade.io/api-reference/s3-gateway and then https://github.com/minio/minio-js for reference
-K
Thanks for the fast reply!
I’ll take a look at those libs and consider it.
For debugging, i did a fresh install for both node repo and go. Here’s the steps I took with comments:
- Testing the install with
npm i
without bothering to do go package setup:
returns error needing storj/lib/uplinkc
It requires local building of libuplinkc with GO, any way to package a binary?
this command: (cd $HOME/go/src/storj.io/storj/lib/uplinkc && go build -o libuplinkc.so -buildmode=c-shared ) && cp $HOME/go/src/storj.io/storj/lib/uplinkc/libuplinkc.* ./ && cp $HOME/go/src/storj.io/storj/lib/uplinkc/uplink_definitions.h ./ && node-gyp configure && node-gyp rebuild
installing with go, i get:
package github.com/spacemonkeygo/monkit/v3: code in directory /Users/me/go/src/github.com/spacemonkeygo/monkit expects import "github.com/spacemonkeygo/monkit/v3"
otherwise, no issues
going back to install storj-nodejs (only using the repo, not imported to project)
../../../common/macaroon/apikey.go:13:2: code in directory /Users/me/go/src/github.com/spacemonkeygo/monkit expects import "github.com/spacemonkeygo/monkit/v3"
This is where it fails.
Hopefully this is a simple fix?
Node: v12.13.1
npm: 6.12.1
go: go1.12.7 darwin/amd64
@utropicmedia-karl Any updates on this?
I saw there were some updates to the main uplink repo and the nodejs lib. I tried again with recent versions using go 1.13.3, but still get issues mentioned above. Seems others are having similar issues: Error while go get storj.io/storj/lib/uplink
Is this a problem with my setup, or is this a known bug?
@TrevorJTClarke - there is a known bug in the build process. The issue is that you need to now clone the uplinkc repo (git clone https://github.com/storj/uplink-c) and build the .so file from that clone to use with the binding. We’re aware of the build issue and are working on a fix for next week.
If you want to use prior to the build update you can just clone the above repo into your GOPATH and re-run npm install on the bindings.
Thanks.
@utropicmedia-karl thanks, ill try that!
@utropicmedia-karl attempted to do the build with go 1.14.2:
make build
go build -ldflags="-s -w" -buildmode c-shared -o .build/uplink.so .
# runtime/cgo
In file included from gcc_libinit.c:8:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/pthread.h:232:66: error: unknown type name 'size_t'
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/pthread.h:249:43: error: unknown type name 'size_t'
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/pthread.h:256:66: error: unknown type name 'size_t'
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/pthread.h:524:1: error: unknown type name 'size_t'
gcc_libinit.c:97:18: error: variable has incomplete type 'struct timespec'
gcc_libinit.c:97:9: note: forward declaration of 'struct timespec'
gcc_libinit.c:110:3: error: implicit declaration of function 'nanosleep' is invalid in C99 [-Werror,-Wimplicit-function-declaration]
make: *** [build] Error 2
Will the next week release be the uplink or uplink-c? or both?
thanks!
