Temp folder - cleanup?
Hi All,
I currently have over 900,000 items in my temp folder and is using over 1.2TB of data.
Should these files clean up automatically like the trash folder ? Can I manually clean them up, over a certain age ?
Thanks.
Large temporary folder
Is it implemented to delete temp files on start?
This sounds like a really good indicator that something is wrong with your node. These should not remain for longer than the transfer takes to complete. It may be that the node is having trouble moving them to the permanent storage location. I’m not sure what is going on, but this is not normal.
