I don’t know. The Pastebin log does not look complete.
Maybe post log from node startup. You can skip anything concerning satellite “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”.
For how long did you not receive data from the other satellites?
Yes i have tried with yougetsignal. And i have also stopped, rm’d, and then restarted the node multiple times over the past days (maybe 3 or 4 times in total).
I truly beleive this to be the full log. I restarted the node AFTER i took the dump of the log. I will restart the node and dump the log again, ignore the loggin stuff, its sending all my nodes logs to one centralized sql database for simplicity take. The logging system is infact working fine.
Your node shows an external address without an IP or hostname. Which means it’s for some reason not getting the parameters from the run command. I suggest copying the run command from the documentation again and filling in the values. Keep it as a multiline command in a shell script so you can easily start the node again should the need arise.
Also on around 16 nodes i setup for new hard drives a few days ago - i’m seeing this error on 3 of them. All the docker run commands are identical except for 6 unique values (mainly IP, ports, identity and the storage files).
So why do some of them error and not the others. That’s the part i’m confused on.
Your timestamps are in complete random order and the restart is not part of this log. I’m not sure what you’re doing to get these logs, but these seem like just random log lines in random order and they don’t include the restart.
I noticed, I’m saying please do use the multiline. The closer you stick to the documentation, the less chance of an error sneaking in.
Additionally, did you make any changes to the config.yaml?
I use graylog to aggregate the logs. Let me figure out why its spitting out stuff in completely random order, that’s not how i see it in the web interfface.
