a raspberry pi 4 with 2gb of ram running ubuntu 20.04 lts 64 bits,a wireguard VPN in order to do remote support.
the storj is in an external 6tb hdd from WD connected by usb. the conection is 1gbps simmetrical fiber optic
and don’t know what more can I say about my setup that could help to solve this
Unable to get satellite system time means you can’t reach them. If you would be able to reach the satellite but your clock would be off you would see a different message including the offset.
2021-10-19T09:08:57.327Z INFO Configuration loaded {"Location": "-----------------"}
2021-10-19T09:08:57.329Z INFO Operator email {"Address": "---------@-------.-----"}
2021-10-19T09:08:57.329Z INFO Operator wallet {"Address": "0x------------------------------"}
2021-10-19T09:08:58.094Z INFO Telemetry enabled {"instance ID": "------------------------------------------"}
2021-10-19T09:08:58.194Z INFO db.migration Database Version {"version": 53}
2021-10-19T09:08:58.516Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock.
2021-10-19T09:09:18.520Z ERROR preflight:localtime unable to get satellite system time {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "error": "rpc: dial tcp 34.94.230.169:7777: i/o timeout", "errorVerbose": "rpc: dial tcp 34.94.230.169:7777: i/o timeout\n\tstorj.io/common/rpc.TCPConnector.DialContextUnencrypted:107\n\tstorj.io/common/rpc.TCPConnector.DialContext:71\n\tstorj.io/common/rpc.Dialer.dialEncryptedConn:220\n\tstorj.io/common/rpc.Dialer.DialNodeURL.func1:110\n\tstorj.io/common/rpc/rpcpool.(*Pool).get:105\n\tstorj.io/common/rpc/rpcpool.(*Pool).Get:128\n\tstorj.io/common/rpc.Dialer.dialPool:186\n\tstorj.io/common/rpc.Dialer.DialNodeURL:109\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).getSatelliteTime:110\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check.func1:67\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-10-19T09:09:18.520Z ERROR preflight:localtime unable to get satellite system time {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "error": "rpc: dial tcp 35.241.93.116:7777: i/o timeout", "errorVerbose": "rpc: dial tcp 35.241.93.116:7777: i/o timeout\n\tstorj.io/common/rpc.TCPConnector.DialContextUnencrypted:107\n\tstorj.io/common/rpc.TCPConnector.DialContext:71\n\tstorj.io/common/rpc.Dialer.dialEncryptedConn:220\n\tstorj.io/common/rpc.Dialer.DialNodeURL.func1:110\n\tstorj.io/common/rpc/rpcpool.(*Pool).get:105\n\tstorj.io/common/rpc/rpcpool.(*Pool).Get:128\n\tstorj.io/common/rpc.Dialer.dialPool:186\n\tstorj.io/common/rpc.Dialer.DialNodeURL:109\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).getSatelliteTime:110\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check.func1:67\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-10-19T09:09:18.520Z ERROR preflight:localtime unable to get satellite system time {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "error": "rpc: dial tcp 34.86.126.23:7777: i/o timeout", "errorVerbose": "rpc: dial tcp 34.86.126.23:7777: i/o timeout\n\tstorj.io/common/rpc.TCPConnector.DialContextUnencrypted:107\n\tstorj.io/common/rpc.TCPConnector.DialContext:71\n\tstorj.io/common/rpc.Dialer.dialEncryptedConn:220\n\tstorj.io/common/rpc.Dialer.DialNodeURL.func1:110\n\tstorj.io/common/rpc/rpcpool.(*Pool).get:105\n\tstorj.io/common/rpc/rpcpool.(*Pool).Get:128\n\tstorj.io/common/rpc.Dialer.dialPool:186\n\tstorj.io/common/rpc.Dialer.DialNodeURL:109\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).getSatelliteTime:110\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check.func1:67\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-10-19T09:09:18.520Z ERROR preflight:localtime unable to get satellite system time {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "error": "rpc: dial tcp 34.107.91.2:7777: i/o timeout", "errorVerbose": "rpc: dial tcp 34.107.91.2:7777: i/o timeout\n\tstorj.io/common/rpc.TCPConnector.DialContextUnencrypted:107\n\tstorj.io/common/rpc.TCPConnector.DialContext:71\n\tstorj.io/common/rpc.Dialer.dialEncryptedConn:220\n\tstorj.io/common/rpc.Dialer.DialNodeURL.func1:110\n\tstorj.io/common/rpc/rpcpool.(*Pool).get:105\n\tstorj.io/common/rpc/rpcpool.(*Pool).Get:128\n\tstorj.io/common/rpc.Dialer.dialPool:186\n\tstorj.io/common/rpc.Dialer.DialNodeURL:109\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).getSatelliteTime:110\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check.func1:67\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-10-19T09:09:18.521Z ERROR preflight:localtime unable to get satellite system time {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "error": "rpc: dial tcp 34.86.70.247:7777: i/o timeout", "errorVerbose": "rpc: dial tcp 34.86.70.247:7777: i/o timeout\n\tstorj.io/common/rpc.TCPConnector.DialContextUnencrypted:107\n\tstorj.io/common/rpc.TCPConnector.DialContext:71\n\tstorj.io/common/rpc.Dialer.dialEncryptedConn:220\n\tstorj.io/common/rpc.Dialer.DialNodeURL.func1:110\n\tstorj.io/common/rpc/rpcpool.(*Pool).get:105\n\tstorj.io/common/rpc/rpcpool.(*Pool).Get:128\n\tstorj.io/common/rpc.Dialer.dialPool:186\n\tstorj.io/common/rpc.Dialer.DialNodeURL:109\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).getSatelliteTime:110\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check.func1:67\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-10-19T09:09:18.521Z ERROR preflight:localtime unable to get satellite system time {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "error": "rpc: dial tcp 35.228.118.14:7777: i/o timeout", "errorVerbose": "rpc: dial tcp 35.228.118.14:7777: i/o timeout\n\tstorj.io/common/rpc.TCPConnector.DialContextUnencrypted:107\n\tstorj.io/common/rpc.TCPConnector.DialContext:71\n\tstorj.io/common/rpc.Dialer.dialEncryptedConn:220\n\tstorj.io/common/rpc.Dialer.DialNodeURL.func1:110\n\tstorj.io/common/rpc/rpcpool.(*Pool).get:105\n\tstorj.io/common/rpc/rpcpool.(*Pool).Get:128\n\tstorj.io/common/rpc.Dialer.dialPool:186\n\tstorj.io/common/rpc.Dialer.DialNodeURL:109\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).getSatelliteTime:110\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check.func1:67\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-10-19T09:09:18.521Z ERROR Failed preflight check. {"error": "system clock is out of sync: system clock is out of sync with all trusted satellites", "errorVerbose": "system clock is out of sync: system clock is out of sync with all trusted satellites\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check:96\n\tstorj.io/storj/storagenode.(*Peer).Run:846\n\tmain.cmdRun:218\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.ExecCustomDebug:70\n\tmain.main:385\n\truntime.main:255"}
Error: system clock is out of sync: system clock is out of sync with all trusted satellites
2021-10-19T09:09:21.712Z INFO Configuration loaded {"-----------"}
2021-10-19T09:09:21.714Z INFO Operator email {"Address": "-----------------"}
2021-10-19T09:09:21.714Z INFO Operator wallet {"Address": "-------------------------------"}
2021-10-19T09:09:22.501Z INFO Telemetry enabled {"instance ID": "---------------------------------------"}
2021-10-19T09:09:22.717Z INFO db.migration Database Version {"version": 53}
2021-10-19T09:09:22.967Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock.
This is not a common error, but the other times this has occurred SNO’s have found a local network issue with port 7777 traffic (the one used for satellite communications) or ended up reinstalling the node (with the same identity and data).
just reinstalled this node like a month ago with a fresh new ubuntu because the last install was just freezing itself and the whole machine for no reason.
¿any way I can test the 7777 port as client? ¿anyplace where I can manually send a ping or something like that trought an specific port?
thanks for the help,I’m triying to avoid another reinstall as posible.
Ok seems that I’m not able to get a response,so seems my node can’t connect to us2.storj.io neither port 7777 or default ping port
triyed ping from my laptop in a different network location and seems to be working,with the same dns
I’m using google dns 8.8.8.8 as primary dns and cloudflare 1.1.1.1 as the secondary one, is strange to have some dns issues with this two
¿any way I can enforce the dns to the raspberry itself? is supposed to be taken by the DHCP config frm the router but maybe the ubuntu machine has misplaced it or is using another dns
