Most of the time, posts are triggered by negative results. So, this is a positive result post.
I am pleased to report that my storage node running on GNU/Linux and Docker updated to 0.34.6 without error and without fiddling with Watchtower.
Can confirm that. Update worked without a problem.
Watchtower did his job (with only a log entry once it found the new image, so be patient during the next update).
rock64 Debian checking in. Everything went according to plan.
Raspberry Pi3 B+. All working well.
My upgrade on Ubuntu 18.4 went fine.
The node dashboard however using Brave Browser is a mess, clearing cache fixed the issue. On Safari it looks fine though.
One windows node of mine updated, but the update service stopped after the update.
Other than that all good, Synology docker updated and my RPIs as well.
Everything fine on unraid
Again… I am pleased to report that my storage node running on GNU/Linux and Docker updated to 0.35.3 without error and without fiddling with Watchtower.
May 2020 - New Version
All updates between 0.35.3 and the current, as of this post, Version 1.4.2 worked without any problems.
Since I activated watchtower, I have had zero problems with the automated update process.
The Docker desktop for Windows rolled back to the stable version 2.1.0.5 and working without any issues.
Windows GUI node - working without problem, successfully automatically migrated to 1.4.2.
Windows Docker node - working without problem, successfully automatically migrated to 1.4.2.
Raspberry Pi3 - working without problem, successfully automatically migrated to 1.4.2.
Auto update to 1.6.4 via watchtower went just fine.
No hiccups in the logs. Downloads going quite well. Total RAM usage about 100 MB.
Version 1.9.5
Auto Update via watchtower…
Synology ds 918+ 1x watchtower for two storagenodes - No problems
Synology ds 218+ 4x watchtower for 4x nodes - No problems
Watchtower work Ok every update
Version 1.10.1
v1.10.1
v1.10.1
Windows GUI, Windows Docker 1.10.1 no problem
Ubuntu 18.04 no problems at all
Raspberry Pi 3B+ 1.10.1 no problem too
