That’s the technical part.
Any news you can pass on the sales pipeline and the customers? For me that’s the most interesting part.
Same stuff, not my node.
I am on the technical side and don’t feel comfortable talking about sales. That is outside my comfort zone.
Don’t know what you’ve tweaked but I’ve just seen the highest ingress spike on all my nodes so far…
Currently around 50 Mbps avg per node, peak 200 Mbps
All of my 12 nodes are “preferred”? Seems unlikely, surely…
these are the right settings!
Help, will need more RAM! ![]()
The new node selection is awesome. More than twice the troughput and from what I can see it didn’t overload the nodes this time. Looks promising. I will write a few words about the node selection later.
Maybe one more advice. If you have a concurrency limit set now would be the time to remove it. No matter how bad your node is the new node selection should scale down the request rate automatically and not overload your node anymore. Just try it out.
Sorry, just to be clear:
Is this storage2.max-concurrent-requests: ?
yea that’s the one.
(20 chars)
Between the IPv6 thread and this, I’ll pick this to spend my night on. Have to go back and figure out what the load actually was (I’m thinking waiting on IO) since the hosts didn’t feel sluggish at all even with some of them peaking at 1.7K load.
Ok while you are removing any concurrency limit you might have set I will explain how the node selection actually works.
When a segment gets commited to the database it will contain the nodes that have been fast enough and it will be missing the nodes that got long tail canceld. The satellite calculates a success rate for each node with that.
The node selection takes that success rate. Instead of 110 total nodes it selectes 220 nodes at first and compares them in pairs and pick the one with the higher success rate. So it throws away the slow nodes. We call this the power of 2 node selection. The benefit of this method is that the risk for a stomping herd effect is low. This effect means the selection of a group of nodes that has a high success rate but because the node selection overshoots the goal the nodes gets selected too many times and success rate decreases. At the same time another group of nodes recovers and is now the new vicitm of a node selection with stomping herd effect. Power of 2 choice is build to minimize that risk.
They count possible ingress now but calling it still ingress. So this is not real. ![]()
Well, my success rate is still above 98% so most of it does count ![]()
You are on the wrong party. There wasn’t a single storage node dashboard screenshot. I was watching my nodes with grafana and netdata and it was looking real good.
How does the new node selection deal with /24? Does it still count them all as one?
