Updates on Test Data
I’ve only ever seen 30 days mentioned. Do you have a link?
I just checked a node where I deleted databases 4 days ago. Almost all TTL data is 30 days.
I’m looking at my nodes’ databases.
select piece_expiration from piece_expirations order by rowid desc limit 10;
2024-07-07 01:44:56.581389+00:00
2024-07-14 01:44:34.74594+00:00
2024-07-14 01:44:48.675778+00:00
2024-07-14 01:44:45.278975+00:00
2024-07-14 01:44:41.918976+00:00
2024-07-14 01:44:50.715372+00:00
2024-07-14 01:45:10.172953+00:00
2024-07-14 01:44:34.042397+00:00
2024-07-14 01:45:10.252893+00:00
2024-07-14 01:44:59.720131+00:00
Is that maybe test data uploaded 2 weeks ago?
order by rowid desc shows the most recently added entries.
About two weeks ago littleskunk mentioned some TTL data accidentally got sent to the trash (reusing filenames is like a delete+reupload I guess?). Perhaps they’re filling that hole so they get the amount of TTL-expiring data each day as they want?
Is it from a Saltlake satellite’s customers?
exactly, unfortunately…
Since it’s being deleted, well, it will use the trash folder.
Yes that observation is correct. No deals are signed yet but we have some possible start dates. The challenge is to get enough throughput on day 1. Adding surge nodes takes a bit of time. Reducing the amount of testdata we are allocating will buy us time. It is not a solution. The customers are going to catch up and we end up in the same situation as we are now. But we can use that extra time to order more surge nodes.
There was also a debate internally why we don’t stop uploading. That would be even better for surge node planning. But there is a trust issue. We don’t want you to lose trust. So for now we have to continue uploading. It might change the moment deals are getting signed.
Nothing to lose. Stop those fake data uploads.
Just untrust SLC and the uploads are going to stop for you.
Did somebody say more SLC data for me? Because I’m OK with more SLC data for me. Totally down with it. I’m chill. We cool. Just keep sending those ones and zeroes…
also related payout to your wallet…
Even yours, @pangolin
But well. It’s fully upper on you - make it untrusted and the problem is solved.
If customers don’t sign this will stop anyway. SNOs knowing that with or without fake uploads.
You know there is a signature on the paper from both sides. Just think about the conditions that are required for the company to sign these deals. Stopping the uploads is the equivalent of telling no these customers even if they would like to use us.
Out of curiosity—do the prospective customers follow our discussions here? Are they happy for honesty, or worried about SNO behavior?
They’re probably looking to see if they’re getting the performance they expect for the money they pay: and don’t care about a few yahoos in a forum. People may talk about a lot of stuff: but just watch what their actions are when they’re getting paid :wink:
Although there are currently 11000 full nodes, my ingress is the same as when there where 8000 full nodes. I still don’t get why ingress didn’t increase even a little bit.
I spread the load over multiple nodes, each node have its own disk, plenty of memory and cpu resources. And to reduce the iops, I moved the databases and log file to an other disk. But ingress is still hovering around 110mbit.
Also checked the successrate. Overall I have a (ingress) successrate of 97.x%.
Am I just unlucky that I’m to far away? Are others closer by and win the races more often? Or is it just that there is not enough data uploaded onto the network to fully utilize my bandwidth?
Overall for this month I got 25,5TB of ingress (measured on my storj vlan in pfsense), I’m not entire sure how much extra disk space is still occupied compared to last month. But not to shabby for the current load, but I wouldn’t mind if it would be much more…
Oh, and I don’t mind that it is test data.
Maybe my expectations are just wrong. But when there are concerns about customers upload speeds, I though that my ingress load would be at least a bit higher
This month I got 75TB ingress, even with some problems due to performance (or rather lack of it) some times.
Your success rate from at least saltlake should be higher.
OTOH, today my ingress was hovering around 120mbps, but it was higher in the past:
(some dips are there because of how the test was performed and some are definitely because my node was not fast enough)
I am still trying to figure out whether this is because the traffic has dropped or because my node it too slow. I just restarted my node VM (I needed to expand the virtual disk) and changed some settings, we will see how it runs now.
Right now it is difficult to find out if the traffic is low because the node is too slow or just because nobody is uploading. Storj said that at some point they will add a way to know how often a node is selected by the new algorithm, hopefully that will improve things. However, I’m sure right now they have more important things to do.
This doesn’t fit your chart. Are there other network interfaces? :thinking:
