Or to process bloom filters if only there were any… ![]()
In my had I was adding sugar free ![]()
Is it possible we can get a new round of garbage collection for this weekend?
This is mean that someone deleted the TTL data before expire, so the garbage collector moved it to the trash and now the TTL is expired, but the piece already removed. So, kind of expected.
12,600,000 IOPS?
What’s model?
Or is it an amount of pieces?
It’s a super old Crucial m4 120GB ssd from 2013. Here are my logs:
2024-07-02T22:42:17Z INFO db.migration.58 Remove unused trash column {"Process": "storagenode"}
2024-07-02T22:43:28Z INFO db.migration.59 Remove unused deletion_failed_at column {"Process": "storagenode"}
2024-07-02T22:44:51Z INFO db.migration.60 Overhaul piece_expirations {"Process": "storagenode"}
2024-07-02T22:46:26Z INFO db.migration Database Version {"Process": "storagenode", "version": 60}
This is running on ZFS with compression enabled so it might just be doing everything in RAM, while I did observe 200 MB/s writes to the SSD during migration. I have also migrated another node whose SSD is on XFS (Samsung 840 250GB), and it takes about 10 minutes, with 40 MB/s writes.
Edit: Now that I read your question more carefully, 12600k is an Intel CPU xd
Intel 12600k I suppose
Thank you for clarification, I just wondered was there a mistype or I just missed something.
Could you guys have a topic where all these infos are announced only?
There are just too many topics in parallel with a lotof conversations and its hard to find infos/facts what is your plans, like how much test data is planned, how long, why is it stopped and what are yours current focus and a lot of reading is neccessary just to get these.
They’re using the “Announcements” Category. There’s a post about test data. And another about business plans.
Two threads in the same Category. That’s too much to keep up with?
The only required reading is checking email for “Your Node has Gone Offline” messages. Anything else is optional because you’re curious… in which case don’t expect to be spoon-fed ![]()
This thread has over 1600 replies, it may be a bit much for someone who does not read it all the time.
Yes, as someone who doesn’t visit the forum often it would be tedious to get all the information. I would like to suggest to visit the Storjling’s profile and read their activity which shows their replies.
Yes this is my main point, and sometimes days goes by when there is only talk about specific systems or builds, logs etc and then 1 single comment with an update what is gonna happen and then again a few hundred comment on a sidetopic.
So lets continue some small talk to make this thread even longer? ![]()
What did you have for breakfast today? ![]()
In 2024, they should have a Telegram channel with announcements, not a forum topic.
Roger that.
I think it would be nice to have something like a notice board!
It was important content, but it felt like a comment since it was in the middle of the article.
What is wrong with the link to all the messages he posted? That is what you are looking for. Why you keep requesting something that is already there?
