It depends. That data is meant as reserved capacity. If customers are starting to utilize some of that capacity, it will be less on SLC and more on the other Sats. But this is all fluid, as it depends on customer trends. We want the space to be available to the customers and not used up because we are holding it on SLC. So, if a customer is ready to utilize a chunk of that data we have to have it available and thus it gets released. The exact timing of when a customer uses that data isnt up to us. We are just making sure the capacity is there.
And, of course the SLC data could go up if more reserved capacity is asked for. And it can go down as it gets released to be used. Thus, it is fluid and such definitive pins on how much capacity will be in one place or another is not guaranteed.
Replying to myself, as the math is confusing me. If the targets add up to 30PB of capacity-reservation… then to maintain it SLC would have to be uploading 1PB/day steady-state to keep up with 30-day-TTL data expiring… wouldn’t it?
If a 1Gbps Internet connection can move around 10TB/day… then SLC would have to fill a 100Gbps connection 24x7. I can’t imagine how much Storj is paying for that class of bandwidth.
Or did I add it up wrong? If targets are quarterly… wouldn’t it makes sense to have 90-day TTL… so the required upload rate would be 1/3rd? (You can still force-delete TTL files if you need the space back sooner).
(Edit: Also, I want a pic of SLC’s upload hardware: it must be beefy!)
(Edit #2: Is this worse than I think… because to have space to hold 30PB of customer files… you’d have to upload around 2.7x that amount to the network? So 2.7PB SLC uploads/day?)
(Edit #3: I guess I don’t need to know these answers. I’m content if I see my HDD fill a bit more every month… )
The test data should be autoremoved without a garbage collector and waiting in the trash
Thus 90 days is not better, because it cannot help to test a throughput, if the node would be full. Also these customers have a similar usage pattern as we emulating with Saltlake, include segments size and levels of TTLs (of course, this is an estimate based on the information we have about how they plan to use the Storj network). Therefore, it is important to conduct the most accurate testing possible.
And it’s already allowed us to optimize our code to have more high throughput than before, it’s also helped to reveal several bugs and fix some of them.
Taking a look at one of the big SNOs: it looks like they lose 15-20TB per day when SLC isn’t firing out data. Imagine emptying an entire HDD every day, yikes!
Do not panic. This is a usual everyday in the distributed storage with an unpredictable usage…
Just imagine - our storage is used by real humans. Do you still expect a predictable results? Even for a day…
By the way, did you check the usage on the dashboard? Does it match the usage reported by the OS? Your node may believe that’s full, if the databases are not updated with the actual usage.
I do not think that they are talked about the used space, they are talking about the ingress.
Yes, the GC would move data to the trash, but it would not increase a free space (to make the node to be not full again). Only the TTL collector and trash-filewalker can do it.
