This is fairly normal for customers, even large enterprise customers. Customers typically do not have a list of security requirements (some do especially government related entities).
There are usually two types of enterprise customers:
A business unit such as a marketing department is trying to find a solution that the enterprise IT department isn’t able to offer (or is not a good fit for some reason).
The IT department of an enterprise looking to offer new capabilities or reduce costs.
In the first case, the risk officer (or IT security group) is not in the loop until the contract is ready to be signed, I went through this so many times. As internal risk management we try to train other departments to involve us very early.
In the second case, it is far more likely that the security or risk team is involved early and know to be part of the early conversations and options.
In either case, there is rarely a hard ‘requirement’ to have a vendor provide a SOC 2. The discussion goes like this internally between security and the department wanting a new vendor or service:
What kind of data is involved? (we then figure out the risk level)
Is there system integration involved with existing IT systems? (more risk assessment)
Depending upon the level of risk we ask how secure is the vendor’s system?
Next how can they prove it? (If they have SOC 2, ISO 27001, NIST this makes it much easier)
If the project needs a secure system and the vendor doesn’t have good proof, we can still consider the proposal but the amount of effort is very, very high and the vendor service had better offer us extremely high value.
I have also been in situations where some department simply used a credit card to on board a service without security approval but needed privileged access. Often times we simply could not grant them access due to the risk. (Grammarly.com was an example where internal corporate information was collected at their sites and they could not provide reasonable security assurances.)
The bottom line is that is is not reasonable to expect a customer to fully understand their own security requirements in advance. Security is not binary. Security is expensive and is always a balance between risk and value. A competent risk or security team will have a good understanding of corporate risk appetite and business needs. New and unique systems, including Storj, are considered high risk for sensitive data due to a lack of industry wide adoption. In some cases a company’s cyber insurance policy may not cover or allow such services.
Select doesn’t operate like the public side. Each customer that uses it has specific needs and it is scoped around those needs only. Where as the public side may have nodes all over the world with common redundancy, if a customer doesn’t need that level of redundancy or distribution, it won’t be necessarily built out for them that way in Select. So, even if you were able to compare the two, it would be Apples to Oranges.
For me it is good that this customer chose different parameters. It is better to keep this kind of low TTL traffic from the public network because it is simply not profitable given the current rules. Some of my nodes are still, after more than 30 days, busy deleting data matched by BFs. I realise this is because of past bugs in in testing, but an IOP is and IOP after all.
That doesn’t show how iops affect unlink performance: as (it doesn’t appear) you
varied your hardware iops between test runs? You simply looked at the 20/sec that were hitting your disk and guessed faster-wouldn’t-be-better. Do a bulk delete from a SSD, then delete the same set of files from a HDD: and if you get broadly similar performance you can say iops don’t affect unlink.
However…
When I was testing ZFS metadata-device sizing: I unpacked the same tar’d node many times and deleted it. The SSD setups smoked the HDD on delete speeds. So, same set of millions of files… only the hardware capabilities changed. Both were SATA devices on the same controller. I didn’t test like you did: but my feel is that iops very much matter for any update to any filesystem on any OS.
Edit: I think I was typing while you edited, so now I’ll edit - that yeah for a node it isn’t deleting enough every day for delete speeds to be an issue: totally agree!
No. I looked at the time spent in the call and concluded that if iops were the bottleneck it would increase the rate of the deletes until the bottleneck is reached.
It was bulk delete (by a storagenode) from an SSD — the special device. All delete traffic went to SSD, which was not even close to half loaded. I only mentioned 20 iops on HDD to diffuse any objection that it’s iops limited on HDD. All metadata is on Intel nvme 2TB SSD.
Right. Of course slow iops will affect deletes once drive capabilities are reached. But in this case, deletes are not going fast enough for iops to be a problem. Hence, there is something else that is done synchronously or sequentially that wastes time. Depending on which one it is — deleting in parallel may or may not help.
But either way — 200 files per second is way too slow.
Side note — it’s not CPU bound either — I’ve doubled the CPU clock at it made no difference.
It could have been memory/cache flush/whatever limited (this is dual xeon system), but I did not have time to investigate further yet.
SNOs should have no say over when customers choose to delete their files. If they’re paying the bills… they can delete them… by TTL or by hand… whenever they want.
That is intensional. I was lucky to be on this conference a year earlier. I was also questioning the wording the sales people are demonstrating. Well on that conference it was my turn to answer customer question. Turns out if you tell these customers that the data is uploaded to raspberry pi nodes and better the conversation is over before you can explain end to end encryption and reed solomon encoding. Even if you say people like you and me might run a server at home they run away the moment you finish that sentence. Do you know how you can get them to join the network? Just say datacenter nodes all over the world, explain how the above mentioned features make a great 0 trust system and at the end extend the scope and explain that with our solution even a raspberry pi can participate and doesn’t put the customer data at risk. Thats what the sales team is good at. Approach the customer and have a conversation. Tell them everything they need to know in the order that works best for that. So you might call it a little sales lie but only as a door opener and just minutes later in the conversation the customer will get the full picture.
There is no lie. Data is indeed stored in the datacenters across the world.
There is not even need to bend the meaning of the word “datacenter” to include aforementioned “points of presence”: my shed in the yard where I house computer systems and associated communication and storage equipment is a datacenter, by definition, and storj has presence there.
Nobody claimed that all datacenters are hyperscalers, and critical audience can deduce that 23000 points of presence must involve something else besides Amazon and Google warehouses in Reno, NV.
