i tried installing golem, ran honey something for a while, but didn’t really run well without a gpu, folding@home, but dropped that because it was mostly pointless, and affected my successrates at the time i believe… not totally sure… stopped it for a reason… maybe i was just trying to do to much…
now where was i … renting out computation time / storage, right.
Never was able to get golem it to work… else i got a small fleet of vm’s containers for local services, like home streaming, even tho thats kinda pointless these days since everything is really online…
doubt i will kill the streaming server because i spent way to much time on getting it to work and sorting the series… and really theses days with the capacity i use on storj… its just a drop in a bucket xD
all the vm’s and memory usage is quickly an issue with only 48gb ram and half of that is dedicated for the ZFS ARC most of the time… so after a few windows vm’s and a few linux containers / vm’s memory can quickly become scarce…
the idea behind golem is pretty cool, distributed computing ( currently render cloud for blender i think)
not sure what else one can do with it… seems like some very smart people that are making it… maybe a bit to smart because i never successfully got it working… might be easier on windows, on linux is just … a mess imo
spent a ton of time on that, and still kinda got stuff i need to finish on the storj setup, so haven’t really had the greatest focus on adding stuff…
MQL5 is one of the next ones i plan to try out…it’s like processing stockmarket predictions or something, seems pretty cool might return to golem at one point or try it on a windows vm, see if the install is easier there
there are actually a huge number of things out there to try… but most of it seems startup like or really old and not any huge traction…
on top of that as the “CPU WAR” is continuing my computing power becomes more and more pathetic and i don’t have any GPU for the server nor much power overhead to add one…
might delve into doing multiple storage related projects… they seems popular, it’s what my server is best at because i was building it towards that… not much processing in a dual xeon 5630
so after my golem failure and vast waste of time, i refocused on streamlining and doubling down on storj, before i start branching out into either filecoin… which i kinda like to, since it’s such a high entry bar for the recommended hardware and i’m not that far off i believe.
