when? still waiting for the last two rewards
Your node UI should tell you approximately what sized payout to expect. You can compare that to the minimum levels - perhaps you haven’t hit them yet? I think Jan needed at least $13.16 and Dec needed at least $10.37.
They should be making a similar post about Feb stats soon: and with the activity on the ETH network (and the fees that causes) I wouldn’t be surprised if the minimum was even higher for last month.
Go into your node and check the “Payout Information”. Under there will be an “Undistributed payout” amount listed.
I am owed $17 and also didn’t get paid so it’s likely gas fees were high on L1 this month.
They were super high.
