as after some version node installation methond has changed, i am reworking my toolbox also to fix it.
It takes some time, I home i can fix it during this week, i have some solution just need to test it by instaling new nodes.
one more thing.
I see you try to make storage to C drive, what is usualy OS drive. It is strongly not recomended to put node with OS together. your pc start to LAG.
Regarding C drive/volume. My OS is on this drive, situated in physical “disk A”. Physical “Disk B” and physical “Disk C” are only mounted on the C drive (C:\1 and C:\2), instead of using distinct drive letters. Is this still a problem for PC lagging, or is it OK?
How do I use the earnings calculator? Do I need to stop a node first, then select the bandwidth file?
Also, is there a way to set a custom path for the logfile upon installing a new node? Because I like to put it in a separate location, so that my OS drive doesn’t fill up with large logfiles. As a workaround I can just edit the config after installing, of course.
just select node, show its db situated, it will stop node, copy needed dbs and start node, then show results.
You can show log path in config
this is defauld, then just show where you want it and restart node.
log.output: winfile:///C:\Program Files\Storj6\Storage Node\storagenode.log
Do you mean I should edit this manually, or is there a way to do this from inside Toolbox? I would love it if this was an extra option when installing a new node from Toolbox, but I understand if you have more important things to do.
However, my first node is a GUI node that was added through auto-detection. For this node I already had made a custom path for logfile manually. When I try to press “Analyze logs” for this node in Toolbox, I get this message
Is there a way I can modify the node log path in Toolbox, to show it the real location?
