Ah I see, the first two links in this thread link to the older 1.0 and 1.1 versions
Will try the new one, thank you
Thank you also, i updated links, that all taking firsts links.
I canât get audits. The Audits Form opens and says ânode not respondingâ
The node is shown online in the main interface of your toolbox AND in storj gui
do you try on same pc?
Yes, I run the Toolbox from Downloads directory (tried running as admin also).
in your config file dashboard is on localhost or external ip interface?
You mean in the config.yaml? Which specific entry then?
do you add node like in Audit?
yes in config.yaml something:14002
Yeah I added node and it shows up in the list.
Also:
# server address of the api gateway and frontend app
# console.address: 127.0.0.1:14002
you need to write ip is localhost when adding node to toolbox, as in my pc dashboard is runing on pc external interface, so i can get it everyware in local network.
try add like this
in my interface, it show than storagenode process is running, it update every 10s.
node not giving information that it is online. only on web.
Thanks Vadim, that workedâŚI was too stupid to figure it out yesterdayâŚor too drunk
Do you want some screenshots of toolbox with correct english translations? I could make some after work today and share on your discord.
it would be very nice.
I patched problem whet sattelite has 0 stats, version 1.2.1
New update Aded Esrnings calculator, Made by Rene Smeekes @BrightSilence
It has Embeded Python, so no need to instal it additional.
Added new version, 1.4 Added automated gui node search on local pc.
Gonna try this out today, thanks mate
there is also in process, additionl GUI node Instalation tool. then people can make more gui nodes, today it litle bit complicated for most.
