I have been removing the C:\Program Files\Storj every-time. My D: is a second drive on my laptop.
Please create a folder storj on it, if you want to use the path D:\storj as you storage
I did. It still does the same thing.
Please, try this command again
Also, please, share result of the command
ls D:
Try to execute the command from the event with error in the cmd with administrator’s rights, but remove the "C:\Program Files\Storj\Storage Node\config.yaml" first, what error it is produce?
what command are you talking about?
The one in this screenshot.
Did you remove the config.yaml first?
yes. i made sure to remove it.
Please, copy the command from
include quotes, all parameters are important
could you copy a text of the command here (you can replace the private information with placeholder)?
Please, use the three backticks ``` before the command and three after the command.
"C:\Program Files\Storj\Storage Node\storagenode.exe"
This is not enough. You should copy all remained parameters too, include --config-dir, etc.
You should add every option with every info after the option from the error event.
Please, do not omit them.
Could you please copy the whole text of the event?
That was "C:\Program Files\Storj\Storage Node\storagenode.exe setup --config-dir"
None of the others are applicable
Could you please copy the whole text from this event?
