Hey. Different kind of issue, but I’m running out of space on my 8TB drive (all storj data) and would like to add another hard drive, maybe go for a 16TB. Can I use a drive of this size for storj? and is there a way of having a second drive with the windows client without docker? Or should I just be moving the entire Storj Chunk to the bigger drive and wait for multiple drives to become an option? Is that going to be an option?
I wouldn’t count on that happening soon.
You can either use storj for a second node or try out this Win GUI Storj Node Toolbox
That’s a community tool that also has an option to install multiple nodes. Its not officially supported, but I think it’ll work quite well.
I would opt for that and use below link for migration.
