X509: certificate signed by unknown authority for https://tardigrade.io/trusted-satellites
I also get that same error in my nodes on start up, but it doesn’t prevent them from running. Have you tried copying the trust-cache.json file from one of your running nodes to the directory where you are trying to create a new node? Is that the cache you are referring to?
Hmm good idea, maybe it is that file, as far as i understand its just a list of trusted satellites. If they are in there that could be a workaround!
Yes, it’s just a plain text file.
trust-cache.json
  "entries": {
    "https://tardigrade.io/trusted-satellites": [
        "SatelliteURL": {
          "id": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S",
          "host": "us-central-1.tardigrade.io",
          "port": 7777
        "authoritative": true
        "SatelliteURL": {
          "id": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs",
          "host": "europe-west-1.tardigrade.io",
          "port": 7777
        "SatelliteURL": {
          "id": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6",
          "host": "asia-east-1.tardigrade.io",
          "port": 7777
        "SatelliteURL": {
          "id": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE",
          "host": "saltlake.tardigrade.io",
          "port": 7777
        "SatelliteURL": {
          "id": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB",
          "host": "europe-north-1.tardigrade.io",
          "port": 7777
Nope,
-p 192.168.x.x:14002:14002
-p 28967:28967
-e ADDRESS=“ddnsdomain.net:28967”
as I enter the console from inside the same LAN.
The place where the domain is at is only at address, and that is OK.
It took around 4 hours.
Yes it was signed correctly.
I repeated the process listed above three times.
Seems a problem with letsencrypt certificate. I believe CA-Authorities on the container does not have LetsEncrypt root cert.
2020-12-17T04:18:20.714Z ERROR trust Failed to fetch URLs from source {“source”: “https://tardigrade.io/trusted-satellites”, “error”: “HTTP source: Get “https://tardigrade.io/trusted-satellites”: x509: certificate signed by unknown authority”, “errorVerbose”: “HTTP source: Get “https://tardigrade.io/trusted-satellites”: x509: certificate signed by unknown authority\n[tstorj.io/storj/storagenode/trust.](http://tstorj.io/storj/storagenode/trust.(*HTTPSource)
Thank you stefan.
At the moment I am running the node as listed in this other post thread:
Works like a charm, no need for docker, no need for root privileges, integrated in os as standalone, just perfect.
What are you waiting for to develop a .deb package?
I could do it by myself and share it =)
The problem with aarch64 image. Please, use the arm32v6 instead
Yeah this bug does not affect arm32 image.
But as I stated, I am using native binaries mounted as services at OS level. I really prefer this way:
  • Less overhead
  • Lack of docker knowledge
  • I can pack the whole node up inside a drive, in case of OS reinstall, as it where some days ago…
  • Friendly use for debianists and ubuntu users.
Just telling some.
The same issue here.
The same workaround here:
The next version should have a fix and we will need to pull the image manually and change the docker run back to the latest
Get this error in the tail of my logs. Checked and the server can resolve anything plus it is downloading and uploading within the docket container. Not sure if I should be concerned about this on?
2020-12-23T00:44:27.808Z WARN trust Failed to fetch URLs from source; used cache {“source”: “https://tardigrade.io/trusted-satellites”, “error”: “HTTP source: Get “https://tardigrade.io/trusted-satellites”: x509: certificate signed by unknown authority”, “errorVerbose”: “HTTP source: Get “https://tardigrade.io/trusted-satellites”: x509: certificate signed by unknown authority\n\tstorj.io/storj/storagenode/trust.(*HTTPSource).FetchEntries:63\n\tstorj.io/storj/storagenode/trust.(*List).fetchEntries:90\n\tstorj.io/storj/storagenode/trust.(*List).FetchURLs:49\n\tstorj.io/storj/storagenode/trust.(*Pool).fetchURLs:240\n\tstorj.io/storj/storagenode/trust.(*Pool).Refresh:177\n\tstorj.io/storj/storagenode/trust.(*Pool).Run:114\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func1:57\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
PING tardigrade.io (104.198.14.52) 56(84) bytes of data.
64 bytes from 52.14.198.104.bc.googleusercontent.com (104.198.14.52): icmp_seq=1 ttl=106 time=149 ms
64 bytes from
Looks like it can be resolved as well
Have you running your node on FreeNAS?
If so the solution is
I run a synology. The Cert on the machine and from lookup is ok. This message seems to indicate a Cert problem outside my network does it not?
@Alexey @stefanbenten looks like the root cause on the server-side:
Certificate #1: is OK but Certificate #2:
Please inform your responsible person about it because it definitely a big issue and security breach.
The same issue on storj.io site:
Unless these were just fixed I dont see the same errors.
Nevermind I didn’t see the second one to expand. I to see the second one.
no, it not fixed, you can check it with ssllabs and compare for example with github.com.
Certificate #2 - is a big issue.
Yeah your right, but it doesnt even look related to storj at all, Both are using the same one though.
It a wrong configuration on the server side, and Certificate #2 should NOT be here.
