I ask knowledgeable people to comment on the example of my config file. Perhaps something should be added to it or, on the contrary, removed.
version: "3.8"
services:
node-30001:
container_name: node-30001
restart: unless-stopped
privileged: true
stop_grace_period: 300s
logging:
options:
max-size: "300m"
max-file: "3"
ports:
- "10.50.6.195:30001:28967/tcp"
- "10.50.6.195:30001:28967/udp"
- "10.50.6.195:15001:14002"
environment:
- WALLET=0x0AE7C6F8Aeb4A553ac3DD5034e7b14D***
- EMAIL=*@gmail.com
- ADDRESS=node-30001.pve01.***.ru:30001
- BANDWIDTH=5000TB
- STORAGE=7TB
- TZ=Asia/Yekaterinburg
user: "${UID}:${GID}"
volumes:
- type: bind
source: /disk001/node-30001-identity
target: /app/identity
- type: bind
target: /app/config
command: --operator.wallet-features=zksync-era,zksync
node-30002:
container_name: node-30002
privileged: true
logging:
options:
max-size: "300m"
max-file: "3"
ports:
- "10.50.6.195:30002:28967/tcp"
- "10.50.6.195:30002:28967/udp"
- "10.50.6.195:15002:14002"
environment:
- EMAIL=*@gmail.com
- ADDRESS=node-30002.pve01.***.ru:30002
- BANDWIDTH=5000TB
- STORAGE=7TB
volumes:
- type: bind
source: /disk002/node-30002-identity
- type: bind
target: /app/config
bre
February 5, 2025, 2:01pm
2
Hello @snemirov ,
Welcome to the Forum !
I’ve forwarded you question internally and someone will take a look.
Edit: they said it looks fine.
Let’s see what other Forum members think. Always open to more ideas.
Alexey
February 6, 2025, 6:58am
3
snemirov:
privileged: true
usually not needed
I think it’s too low, but well, it’s better than the default 20m x 5.
snemirov:
This is not needed. But you could use it.
You can remove zksync
, it will falling back to ETH, if it would be used.
Also, I do not see a watchtower in your docker-compose.yaml
watchtower:
container_name: watchtower
image: storjlabs/watchtower:latest
restart: always
volumes:
- /var/run/docker.sock:/var/run/docker.sock
command: node-30001 node-30002 watchtower --stop-timeout 300s
Also, I believe, that
snemirov:
version: "3.8"
can be removed as well, if you use a docker compose
command, not the docker-compose
command (they are different).
Thank you for your answer! I plan to use Docker Compose, specifically the latest version.
I’ve never written Compose files before. I ended up with something like this. Will the nodes start?
services:
node-30001:
logging:
options:
max-size: "500m"
max-file: "5"
ports:
environment:
- EMAIL=***@gmail.com
- BANDWIDTH=5000TB
- STORAGE=7TB
volumes:
- type: bind
- type: bind
target: /app/config
node-30002:
logging:
options:
max-size: "500m"
max-file: "5"
ports:
environment:
- BANDWIDTH=5000TB
- STORAGE=7TB
volumes:
- type: bind
- type: bind
target: /app/config
watchtower:
restart: always
volumes:
it’s better not to disclose your wallet and address, you never know…
and the IP, if it is fixed
I think the BANDWIDTH environment variable is obsolete
For Storage Node Operators
webUI dashboard notification (outdated version)
On the storage node webUI dashboard you will see a notification if your storage node is running an outdated version. The first time you might be able to notice that will be the following release.
Bandwidth limits removed
Storage nodes don’t have a bandwidth limit anymore. We removed it from the CLI and webUI dashboard. The old configuration value has no effect anymore and the storage node will keep accepting uploads…
Alexey
February 8, 2025, 9:39am
7
@PieceKeeper absolutely right - the BANDWIDTH
will be ignored, it will use everything what you have.
