4 Filez ca und so? Lese mal am besten die Dokumentation von ganz vorne und lese genau und führe jeden Schritt nochmal durch. Ab hier dann genau aufpassen -> https://documentation.storj.io/dependencies/identity#authorize-the-identity
Eine E-Mail mit der Einladung hast du ja angefordert oder?
EDIT: Sonst noch etwas Geduld haben und dann das schauen -> [VIDEO] Tardigrade Thursday: Set up a Storj storage node on Windows
what about Western Digital Green ssd ? they have low powerusage, max 2.8W on each drive (2x SSD = 5.6W in total). RPI-4 supplies 1.2A in total for all the USB-peripherals, which actually gives 6W. with 0.4W (0,08A) extra
Wow, good find! Ill have some please
i will try this out as soon as it all arrives in the mail
i also have 1 power-backed usb3-sata3 adapter just in case which i will use if this doesnt work
Got my RPI4 booting from my WD Green SSD 240GB, and my other WD Green SSD 1TB ready for storj-node. Both SSDs connected to RPI4 via a simple USB-SATA cable without external power, and system seems stable.
Here is a tip :
mount your data ssd but put the data in a subdirectory, so that the storage node can’t write unless it’s mounted
