It is. The SQLite is not compatible with any network protocols, except iSCSI. Sooner or later you could have a problem with sqlite databases.
The only exception could be if CIFS is shared from the Windows server and the client is Windows too.
You can take a look: https://forum.storj.io/tag/smb
don’t see how that relates to satellites controlling the allocation of data on nodes…
what i was trying to say is if nodes have the same age, no downtime, infinite bandwidth and infinite storage, then they would most likely be 99% the same in data stored and bandwidth used for egress.
atleast for test data which is what we see the most of… but i suspect normal data will be distributed much in the same way… that way it’s easier to keep the network balanced and stable… actually makes perfect sense when you think about it…
i tried using network drives, but didn’t have much luck with it… also it might add latency… ofc it depends on a lot of factors… stuff is rarely impossible, just very difficult xD
i did design my setup to hardwire up to like 1000 hdds into the bus of my server so no need to iscsi, cifs and what not… ofc there will be a bus speed limitation at one point… but i’m betting the internet goes first lol
Thank you for sharing.
Your success rate with the pi3 is about the same with my pi4. For me, I think the upload speed is the bottleneck. I think then I will put the pi3 to my parents’ house. If afterwards it’s $ 2-3 a month, I’m happy. The hardware is already there and will not be used anyway.
Hi sir I just wonder how did you do 24tb on just 1 node?
You didn’t ask me, but RAIDZ1. I just happened to know. ![]()
I use SHR2 on Synology myself.
Hi sir, Im also newbie, what do you mean by node gets vetted? I also have 3.2tb node
You didn’t ask me again, but since I’m at it, haha. Nodes need to succeed 100 audits to get vetted on the corresponding satellite. Until they are they only receive 5% of normal traffic. You can use the earnings calculator to see the progress of vetting on each satellite.
i’m using zfs… but in short i combined a number of drives in a raid solution to get some redundancy and other performance benefits for a large array / pool which i will be using for a wide range of things, like vm’s, storagenode/s, home media storage, network drives and pxe server
and to be more exact.
its currently a pool of two raidz1 vdevs, and when my scrub of the pool is complete i will be adding a 3rd raidz1 vdev to amp up my raw iops the pool can handle.
capacity operations bandwidth pool alloc free read write read write --------------------------------------------- ----- ----- ----- ----- ----- ----- rpool 55.0G 84.0G 0 47 0 637K ata-OCZ-AGILITY3_OCZ-B8LCS0WQ7Z7Q89B6-part3 55.0G 84.0G 0 47 0 637K --------------------------------------------- ----- ----- ----- ----- ----- ----- tank 13.6T 11.0T 2.03K 153 803M 3.63M raidz1 8.13T 8.23T 769 41 406M 1.73M ata-HGST_HUS726060ALA640_AR11021EH2JDXB - - 249 13 136M 590K ata-HGST_HUS726060ALA640_AR11021EH21JAB - - 219 14 135M 590K ata-HGST_HUS726060ALA640_AR31021EH1P62C - - 300 13 135M 590K raidz1 5.43T 2.74T 1.28K 52 396M 577K ata-TOSHIBA_DT01ACA300_531RH5DGS - - 586 18 132M 193K ata-TOSHIBA_DT01ACA300_99PGNAYCS - - 578 17 132M 192K ata-TOSHIBA_DT01ACA300_Z252JW8AS - - 147 16 132M 193K logs - - - - - - ata-OCZ-AGILITY3_OCZ-B8LCS0WQ7Z7Q89B6-part5 63.7M 4.44G 0 58 0 1.34M --------------------------------------------- ----- ----- ----- ----- ----- ----- temp512 9.03T 1.88T 0 0 0 0 ata-HGST_HUS726060ALA640_AR31051EJS7UEJ 4.55T 921G 0 0 0 0 ata-HGST_HUS726060ALA640_AR31051EJSAY0J 4.47T 1002G 0 0 0 0 --------------------------------------------- ----- ----- ----- ----- ----- -----
and looks like it will be fast fast fast lol 3300 reads of a total 800MB pr seconds, and writes should be not far removed from that…and ofc + 50% better in a bit… ofc will take a while to rebalance the data, but didn’t have enough drives to actually have them all in the pool when creating it and migrating my storagenode…
but thats just a balance issue, should solve itself even… if i don’t figure out how to make it rebalance.
and because i don’t have enough 6tb drives it will be a mix of 3tb and 6 tb lol
me ghetto rig
1 node - dedicated NAS with 4 drive bays, currently on raid 1 (SHR1 with 2 HDDs).
10 TBs total storage.
However knowing what I know now, I would have just gone with a cheap Rpi and a 10 TB drive since they would earn the same and the rpi would be cheaper as an initial investment.
SNO’s with higher end gear don’t get paid any different to lower end gear.
Hi! Out of curiosity, would you be willing to share the name of some of these projects? I have a very quick internet connection and plenty of storage that I would like to put to good use. If not, no worries. Cheers. Tiago
14 TB on 3 nodes not full on 2 public IPs with the same provider (5$/m option for labbing)
2 x2TB old nodes full running on corei3 mini-pc hackintoshed on applefs as external USB devices
A macmini i7 as cold standby configured to takeover mini-pc (no failure so far) used for other minings
10TB on synology 412+ in Raid5 not full yet but very fast
All recycled materials with no crash. Just had to slow down the ingress throughput to the minipc no accepting more than 3MBs due to low specs
Planning to start a rapi4 one in july to learn docker ARM
Looking forward the syno backup app to recycle my STORJs AND consolidated Https dashboard
If you are ready to spend time on projects not in prod, Check out golem or Akash network which in currently in challenge phase2 for building a decentralized cloud infrastructure with compute and storage.
Hello Bob,
How do you limit the ingress ?
Thank you.
Siacoin is the only other publicly participate-able project, but I price SC/TB stored like Storj pays but bandwidth a lot cheaper, do not get much for contracts as a result, prices for it are rock bottom with lots of people providing storage and bandwidth for much cheaper. My other projects are just some other non-decentralized side gigs.
Not mine, but randomly saw this single location of 677 nodes in Kassel from storjnet.info ![]()
Thats more then in all of canada must be in a datacenter.
ip geolocations aren’t always correct in germany. E.g. I have vodafone cable and my IP geolocation shows Hannover (which is in the north) even though I live in the very south of Germany… So this is more likely just an ISP location and not a datacenter. I doubt any german datacenter has 677 nodes in it. None of these nodes would make any profit, even if that datacenter had over 100 subnets available.
That’s a reply that someone who has a node in a datacenter lol jk.
Also then explain why it’s so concentrated in one location if that was the case I doubt there’s 617 random people in one location running these nodes too.
Even if it was many subnet it would still be concentrated in one area because if a data center has many subnets would still show it in a location because that’s how it’s setup.
You can see anywhere it’s super concentrated of nodes I can google where a datacenter is located and sure enough there is a datacenter.
Take Canada for an example You Look at Montreal theres a datacenter you look at Toronto there is a datacenter you look at Ottawa no datacenter. Barely any nodes.
