First, be aware that there’s a typo in the instructions on How to add an additional drive? In the Docker version, How to add an additional drive? - Storj Node Operator Docs This should read -p 127.0.0.1:14003:14002 instead of -p 172.0.0.1:14003:14002
I have two 4 Tb hard drive. The first one was a charm to setup, but after several hours, I need help with the other one.
Port forward for Web interface
STORj External 14002 Internal 14002 > 192.168.8.138
STORj2External 14003 Internal 14002 > 192.168.8.138
Port forward for Nodes
STORjNode1 External 28967 Internal 28967 > 192.168.8.138
STORjNode2 External 28968 Internal 28968 > 192.168.8.138
CLI-Set up the Storage Node
docker run --rm -e SETUP=“true” --mount type=bind,source=“C:\Users\STORj\AppData\Roaming\Storj\Identity\storagenode”,destination=/app/identity --mount type=bind,source=“D:\storjC1”,destination=/app/config --name storagenode storjlabs/storagenode:latest
docker run --rm -e SETUP=“true” --mount type=bind,source=“C:\Users\STORj\AppData\Roaming\Storj\Identity\storagenode”,destination=/app/identity --mount type=bind,source=“E:\storjC2”,destination=/app/config --name storagenode2 storjlabs/storagenode:latest
CLI-Run the Storage Nodes
storagenode1
docker run -d --restart unless-stopped --stop-timeout 300 -p 28967:28967/tcp -p 28967:28967/udp -p 127.0.0.1:14002:14002 -e WALLET=“redacted” -e EMAIL="rst@mac.com" -e ADDRESS=“redacted”:28967” -e STORAGE=“3.5TB” --mount type=bind,source=“C:\Users\STORj\AppData\Roaming\Storj\Identity\storagenode”,destination=/app/identity --mount type=bind,source=“D:\storjC1”,destination=/app/config --name storagenode storjlabs/storagenode:latest
storagenode2
docker run -d --restart unless-stopped --stop-timeout 300 -p 28968:28967/tcp -p 28968:28967/udp -p 127.0.0.1:14003:14002 -e ADDRESS=“redacted”:28968” -e WALLET=“redacted”” -e EMAIL="rst@mac.com" -e STORAGE=“3.5TB” --mount type=bind,source=“C:\Users\STORj\AppData\Roaming\Storj\Identity\storagenode”,destination=/app/identity --mount type=bind,source=“E:\storjC2”,destination=/app/config --name storagenode2 storjlabs/storagenode:latest
config.yaml for the first node
console.address: :14002
contact.external-address: “redacted”:28967”
operator.email: “rst@mac.com”
operator.wallet: “redacted”
server.address: :28967
server.private-address: 127.0.0.1:7778
storage.allocated-disk-space: 3.50 TB
config.yaml for the second node
console.address: :14003
contact.external-address: "redacted”:28968”
server.address: :28968
server.private-address: 127.0.0.1:7779
Can anyone spot my error?
