damn that’s a stupid mistake thanks !
EDIT: sorry for spamming the forum this much for such a stupid mistake and losing your time @kevink …
no problem. happy if you get it working.
@kevink really appreciate all of your help on this. So here’s where I’ve gotten to thus far:
got prometheus installed/configured/running on a standalone machine that isn’t currently running a Storj node. Here’s the “targets” page:
got storj-exporter installed on all three machines that are running nodes
got grafana installed on standalone machine
Now when I go to the grafana page (ip:3000) I get the grafana login page.
Try enter admin for username and password.
There is default login: https://grafana.com/docs/grafana/latest/getting-started/getting-started/
ah…just did another google search and figured out that after installing grafana…the default username/password is admin/admin…THEN it asks you to change the password…so I’ll keep plugging along…
yes sorry should have thought about that. I’ll add it to the how-to. glad you got this far! Now you’re almost finished
I just went through the import dashboard steps, and I’m getting an error about “datasource name” not found. Is this normal when first running and I just need to wait? or did I do something wrong?
ah… added the missing steps of adding the datasource.
Uh yeah, I am on Synology with multiple nodes and exporters, without STORJ_API_PORT of each node it did not work at all…
oh yeah I forgot… localhost won’t work with docker… you have to use your ip instead of localhost
What do you mean? STORJ_API_PORT does never have to be used with docker on the same host.
Glad we got it finally working!
Thanks for helping me find what was missing in the how-to ![]()
okay, new question, in my Node Summary Table, as you can see in the previous post, the DQ and SU for all 3 nodes is “No Data” and then Held values for Node 1 and 2 are both “no Data”. any idea what would cause those fields to not be populated? Those fields have not populated with any data still…
Hey guys I know this might sound weird but I run the node on a windows system and cannot seam to understand how to get it working. Any suggestions. Because it seams all of this is just for docker.
Thanks any help much appreciated
Honestly I have no idea. I’ve never seen it unpopulated. Can you check if your databases are ok? Maybe we can continue this in the exporter thread (just to keep things better organized):
Sorry this is indeed all for docker and linux systems. I have no idea how to get it working on windows. You could however run the exporter on your linux machine and have it pointed to the dashboard port on the windows machines.
Although… the exporter is just a python script, so you could just run it directly in windows. You might need to set up some autostart for it though.
No idea about prometheus and grafana on windows though.
so I just found that you had posted a while back, a link to your grafana dashboard
and I just added that one, and it’s showing suspension values…
so not sure why that other one isn’t…I’m not real worried about it, just thought I’d ask. the Storj-web-dashboard has great values for DQ and suspension, so I can’t image that anything is wrong with my databases.
I just checked the screenshot of your last dashboard and it’s not the same as the one I get when I import the json file from the repository:
Can you please remove that dashboard again and add it from the repository?
(by the way: the suspension score from my dashboard is not the same as the suspension mentioned in the new dashboard. in the new dashboard that’s just the suspension status.)
