Yes, it showed as “offline” on the first load with all stats reset. Now I get nothing.
All I did was add
operator.wallet-features: [“zksync”]
to the config file and restart the node!
Panicking I’m going to be penalized now haha. Too much of a coincedance I think that it would Storjs end. Im going to try a reboot of the PC just incase.
EDIT – Panic Over, a restart did indeed solve my issue. Its always the most obvious thing haha.
Perhaps I spoke too soon. Just loaded the dashboard again and its back to not loading
“This site can’t be reached”
Hmm very strange…
Any thoughts?
EDIT – It appears that the service is restarting. I went back into “services” inside windows and low and behold it was not running.
I start it again and a few seconds later it appears to have stopped!
I did get a couple of errors inside windows about disk errors, you know the ones that USB sticks can trigger where it asks you to scan. I just closed the message, but now im thinking maybe something has corrupted?
Storj is installed on the C: drive and data is on a different drive.
Im only 3 weeks in and a little annoyed I will no likely be banned I assume?
PS C:\Users\seanc> Get-Content “$env:ProgramFiles/Storj/Storage Node/storagenode.log” -Tail 20 -Wait
2021-03-28T21:04:38.899+0100 ERROR nodestats:cache Get pricing-model/join date failed {“error”: “context canceled”}
2021-03-28T21:04:38.905+0100 INFO piecestore upload canceled {“Piece ID”: “T4XUZMBFORBBIZF7LNNFD4UJNJ2IJ7C6G7KGPRFDBBXAKMDTYDMA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT_REPAIR”, “Size”: 532480}
2021-03-28T21:04:38.905+0100 INFO piecestore upload canceled {“Piece ID”: “XPJI5ZQMOPR5CXV3SVYHSBXJUFLB6I4OYURHFGNGCH6S6EGHGOAQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT_REPAIR”, “Size”: 311296}
2021-03-28T21:04:40.017+0100 FATAL Unrecoverable error {“error”: “FindNextFile D:\blobs\qstuylguhrn2ozjv4h2c6xpxykd622gtgurhql2k7k75wqaaaaaa\l7: The file or directory is corrupted and unreadable.”}
2021-03-28T21:09:11.445+0100 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
2021-03-28T21:09:11.473+0100 INFO Operator email {“Address”: “@gmail.com”}
2021-03-28T21:09:11.474+0100 INFO Operator wallet {“Address”: “0xC8e7272ad3FD4CD28e13a2180CD9E671330c7224”}
2021-03-28T21:09:12.180+0100 INFO Telemetry enabled {“instance ID”: “14rnAuAovo7Ejaj4Cv67QhNzeGPx3dnm3ECiKXd3BP6siW9drL”}
2021-03-28T21:09:12.278+0100 INFO db.migration Database Version {“version”: 51}
2021-03-28T21:09:14.025+0100 INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2021-03-28T21:09:14.863+0100 INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2021-03-28T21:09:14.863+0100 INFO bandwidth Performing bandwidth usage rollups
2021-03-28T21:09:14.863+0100 INFO Node 14rnAuAovo7Ejaj4Cv67QhNzeGPx3dnm3ECiKXd3BP6siW9drL started
2021-03-28T21:09:14.863+0100 INFO trust Scheduling next refresh {“after”: “5h5m8.495862494s”}
2021-03-28T21:09:14.863+0100 INFO Public server started on [::]:28967
2021-03-28T21:09:14.865+0100 INFO Private server started on 127.0.0.1:7778
2021-03-28T21:09:16.862+0100 ERROR piecestore:cache error getting current used space: {“error”: “FindNextFile D:\blobs\qstuylguhrn2ozjv4h2c6xpxykd622gtgurhql2k7k75wqaaaaaa\l7: The file or directory is corrupted and unreadable.”}
2021-03-28T21:09:16.862+0100 ERROR services unexpected shutdown of a runner {“name”: “piecestore:cache”, “error”: “FindNextFile D:\blobs\qstuylguhrn2ozjv4h2c6xpxykd622gtgurhql2k7k75wqaaaaaa\l7: The file or directory is corrupted and unreadable.”}
2021-03-28T21:09:16.862+0100 ERROR nodestats:cache Get pricing-model/join date failed {“error”: “context canceled”}
2021-03-28T21:09:17.998+0100 FATAL Unrecoverable error {“error”: “FindNextFile D:\blobs\qstuylguhrn2ozjv4h2c6xpxykd622gtgurhql2k7k75wqaaaaaa\l7: The file or directory is corrupted and unreadable.”}
So it does appear to be corrupted?
Hard drive is working fine with all my files on it.
Well, I have gone and removed any stuff I want to keep off the drive for the minute.
You would think that if Storj sees an error/corruption rather than the node just being offline then the SNO would not be penalised for it.
I may just do a full format and start again. The HDD is about 6 years old, but did Storj break it? It looks that way.
I just download a 50gb RAR file to the drive all ok. Went to extract and got errors. That’s twice with a different rar archive so I think the drive is drying to be honest.
3 weeks of Storj seems to have killed it haha. Unless it’s just a major coinsedence?
It sounds like a co-incidence. Although StorJ does use a lot of relatively small files, this kind of usage can highlight existing issues with a drive due to the number of reads.
It could be worth running the drive through a full disk read and write test, then examine the SMART data to check for any un-correctable read/write errors.
I am assuming you used the same identity to start again. Since you wiped data you are at risk of being disqualified once a satellite comes looking for one of the missing pieces. As this node was only three weeks old, I suggest you create and sign a new identity and consider this a completely new node.
Out of curiosity, what did you use to edit the config.yaml file when you added the line for zksync?
Also, you might be interested in this discussion about alternatives to NoIP if you want to avoid the expiring host name problem.
Noted I shall delete the identity and start again.
I used notepad only seeing after to use notepad++. Unsure as to why that would make a difference it is just one line on a text file. I will make sure to Notepad++ this time and backup the original.
