Monitoring with Netdata
Works great but I had problems with the accuracy of load, wherever it wasb read from gave a reading up to 5 times higher. The load on my server right now is 0.11, netdata showed upwards of 0.8 continuously.
Can you explain how you set up netdata to scrape storj statistics?
Only containers/host statistics, not Storj
The link in the first topic to the instruction how to setup it.
It’s working only on Linux
Ah. The topic title is misleading. “Monitoring with netdata” under the “getting started” forum makes me believe I can monitor storj with netdata.
Yes, with tags https://forum.storj.io/tags/monitoring and https://forum.storj.io/tags/hardware
